MacBook Pro A2338 liquid damage repair for a beginner?
  • dbuergi
    • Jul 2024
    • 123
    • Deutschland
    i have a A2338 with water damage on the logic board. Cleaning it showed some heavier corrosion around U7000 and surrounding caps. Some are totally broke.
    I get 5,2v when using both USB-C Ports but until now i didn't make any more tests.
    Since i'm a beginner i want to know next possible steps. I'm not afraid replacing the intersil 9240hi but the other parts with 1mm or 2mm scare me and i don't know where to get replacements.
    I fixed other laptops but this ist my first apple device .
  • mon2
    • Dec 2019
    • 14334
    Hi. Highly suggest to purchase some donor boards for training on soldering and removal of such tiny WLCSP packaged parts like this intersil 9240hi.
    The intersil 9240hi is available from Aliexpress.
    ISL9240 - Buy ISL9240 with free shipping on AliExpress
    • dbuergi
      • Jul 2024
      • 123
      • Deutschland
      Hello mons2,
      thank you for your reply. Do you have any tipps for tools to work on these parts? As stated i worked on boards and have a hot air station, soldering irons and a digital microscope. Would it be easier to use low melt solder or solder paste for such small parts?
      • PITERPENY
        • Jul 2023
        • 455
        • Ukraine
        looking at what's going on around the isl, everything under the isl is corroded! before buying a new isl, reball the old isl! you have all the tools! buy a stencil right away, if not, for the isl and soldering paste for rolling the balls and flux! this will be enough to replace it and all the other components!
        • mon2
          A1466 Macbook Air (Liquid damage repair)
          by mon2
          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
          Macbook AIR Model A1466 Diagnostic 09-01-2021
          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
          Problems & Resolutions
          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
          09-01-2021, 09:31 AM
        • fajfelek
          Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
          by fajfelek
          Hello, First of all thanks you for reading this topic.
          I need your help with identify missing parts on trackpad logic board (661-18430).
          The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
          Please help me with identity parts from blue and red area .
          06-15-2024, 01:41 PM
        • rilley
          MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
          by rilley
          I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
          I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
          My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
          And the resistor L4004 is literally burned.
          From what I see from the schematics, it does not affect any other rails, only the connection to the display...
          07-10-2024, 01:57 AM
        • mitchw
          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
          by mitchw
          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
          I quickly took it apart and washed the liquid residue off the mainboard.
          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
          Now the laptop...
          07-16-2025, 07:55 AM
        • Jenzo
          MacBook A1989 overheating after liquid damage
          by Jenzo
          Hey everyone,
          Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
          I can't figure out how...
          05-13-2023, 07:58 AM
