Sony Vaio VGN-N31M No Power - DEAD
  • rmps
    • Oct 2009
    • 82
    Hi guys,
    I have a Sony Vaio with Motherboard MBX-160 MS72 that have no power, no lights, nothing..
    I checked pin8 of Bios Chip and it only have 0.20v ..
    Power button only have 0.20v too..
    What could it be? Some help?
    Thanks in advance
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: Sony Vaio VGN-N31M No Power - DEAD
    1. check if you have around 19v at PR1 (DCBATOUT).
    2. check PU3. It gives 3.3v to U16 (FLASH BIOS) and U15 (SIO)
    • rmps
      • Oct 2009
      • 82
      PR1 have 0 volts.... :/
      • spleenharvester
        • Mar 2010
        • 903
        Is PQ3 burnt up? There looks like there might be a mark at its top right corner?
        Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
        • rmps
          • Oct 2009
          • 82
          No m8..
          That´s solder paste because i´ve already replaced PQ1, PQ2 and PQ3...
          • spleenharvester
            • Mar 2010
            • 903
            Ah okay, is there any schematic out?
            • sorinac
              • Jul 2013
              • 123
              • Romania
              check pf1 fuse
              and here is the schematic
              • spleenharvester
                • Mar 2010
                • 903
                Definitely check PF1. Check PQ2 also.
                • rmps
                  • Oct 2009
                  • 82
                  PF1 is good
                  PQ2
                  pin1- 19.86v
                  pin2- 19.86v
                  pin3- 19.86v
                  pin4- 19.86v
                  pin5- 0v
                  pin6- 0v
                  pin7- 0v
                  pin8- 0v
                  Also: this is a MS72 board, not MS70 like the schematic above.
                  I think this is the right schematic for this board.
                  Thanks in advance
                  • spleenharvester
                    • Mar 2010
                    • 903
                    Right, so it appears there is a short on DCBATOUT. Here is what I would personally do:
                    1) Measure the resistance of pins 5/6/7/8 of PQ2. I am assuming there probably isn't a short because otherwise there'd be 0v on pins 1/2/3/4.
                    2) If no short is present, work your way around that diagram and try to find a short. I would personally check PD1, and PD6 first.
                    3) If you find a short, start removing components one by one to find the source.
                    You may find the MAX chip needs replacing, it's entirely possible.
                    EDIT: If you did find a short, I would assume either PD6, PC22 or PC24 have gone open circuit, because otherwise it would be 0v on pins 1/2/3/4 too. Someone correct me if I'm wrong.
                    • rmps
                      • Oct 2009
                      • 82
                      SO, i was about to measure what you´ve told me but PD6 is not present... O.o (WTF?)
                      Check picture:
                      (already replaced PC30,PC23,PC22,PC28 and PC24)
                      • spleenharvester
                        • Mar 2010
                        • 903
                        That's pretty weird. Check around for other empty component pads on the board, are they tinned like that one is?
                        Also PC26 and PC27 have what looks to be dry joints and also a blob in between them that could migrate. Maybe worth taking a look at.
                        Aside from that, if the other empty pads on the board are all tinned, I'd just assume it was removed from the design for a reason and carry on without it. Especially if there is a short.
                        EDIT: It's right next to PC22. Is it possible you accidentally desoldered it when replacing PC22?
                        • rmps
                          • Oct 2009
                          • 82
                          Dont know why but PC26 and PC27 are shorted to ground.. The dry joints means that i´ve already took them apart from the board to see if the short was still there... and it was :/
                          • rmps
                            • Oct 2009
                            • 82
                            No my friend... I´m preety sure that PD6 was never there.....
                            • spleenharvester
                              • Mar 2010
                              • 903
                              PC26 and PC27 are on the same line as DCBATOUT. Are you able to confirm that there is a ground short on the whole of that line? On PC8 etc?
                              • rmps
                                • Oct 2009
                                • 82
                                As you can see on the picture, there is no PC8. But all of that is shorted..
                                PC16, PC15, PC14, PC8, PC13, PC4, PC5 and PC1 (All shorted to ground)
                                Along with PC26 and PC27 of course.
                                EDIT: This PQ6 seems suspicious to me. It´s an AO4606. What do u think?
                                EDIT 2: PQ6 pin1 and pin3 are shorted to ground too.... :/
                                • spleenharvester
                                  • Mar 2010
                                  • 903
                                  We are on the same train of thought.
                                  Test for presence of short on PC13 throughout this.
                                  1) Remove PR1 and identify which side of its pads the short is on. As we both know, it will probably still be the DCBATOUT side.
                                  2) Remove PQ6 and test which side of the pads the short is on, if it is still there. Afterwards, leave PQ6 removed for now.
                                  3) If we are unlucky and the short is still there, I would personally remove PQ3 and PD1.
                                  If the short is still closest to the DCBATOUT side with PC13 on, that narrows it down to either that row of caps, or MAX itself. As well as PC26 and PC27 don't forget.
                                  If you still can't find the short it will likely be in another area, but we can cross that bridge if it comes to it.
                                  EDIT: Pins 1 and 3 being shorted are to be expected.
                                  • rmps
                                    • Oct 2009
                                    • 82
                                    Thank you my friend!
                                    Will do just that! But tomorrow... Dinner time here
                                    Thank you once again!
                                    Regards
                                    • spleenharvester
                                      • Mar 2010
                                      • 903
                                      Good luck! I get frustrated as hell when I end up having to remove components haha.
                                      There's always the chance that something connected to DCBATOUT is shorted too, something I forgot about in my last post. But first things first.
                                      • rmps
                                        • Oct 2009
                                        • 82
                                        My friend..
                                        After removing PC1/PC4/PQ3/PD1/PC26/PC27/PQ6/PC30/PC23/PC22/PC28/PC24/PR1/PL1/PL2/PL3 and PL4 the short is still there!!
                                        OMGGGGGG
                                        What the hell is going on in this motherboard? Witchcraft? O.o
                                        DAMN!
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • PopsCaps
                                          Sony Bravia KDL-40V2500 that will not power on
                                          by PopsCaps
                                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                          I do not hear any sound and I cannot see any backlight.
                                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                          03-25-2025, 11:23 AM
                                          Sony VAIO SVF1541M1E Notebook Fit E Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF1541M1E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF1541M1E boardview and SVF1541M1E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...
                                          09-06-2024, 05:27 AM
