Toshiba A300-1EC PSAG0E Strange Problem
  • ahmetozay
    • Jul 2013
    • 73
    • turkey
    Dear Friends, i have this toshiba a300, before it was not responding to the switch, i came accross that the bios battery has flooded and shorted. so i changed it with the new one. Then motherboard stared and worked couple of hours i closed the laptop. In the morning i tried to open it but again no respond to the switch so i flashed the bios with xeltek pro 500s with the lastest rev from toshiba website. the unit came alive again no problem hours of working but when you shut it down again no respond to the switch. everytime i have to program the bios. Everything seems ok . But why the bios erase itself and i have to reprogram it again and again. Any advice would be very apreciated. Thanks and regards
  • lefos
    • Nov 2013
    • 321
    • Greece
    Re: Toshiba A300-1EC PSAG0E Strange Problem
    Does this one have a nec tokin ? Look for a big capacitor behind the cpu slot.
    • tomodachi
      • Apr 2012
      • 610
      • Turkey
      you can try to replace BIOS chip, it might be gone
      • Microbe
        • Feb 2014
        • 17
        • Yemen
        YOU CAN VERIFY CHIP PROGRAM BEFORE REPROGRAM IT TO KNOW IF IT'S THE BIOS OR NOT.
        IF SO JUST REPLACE THE BIOS CHIP AS tomodachi SAID.
        AND IF THE PROGRAM VERIFIED SUCCESSFULLY THEN IT HAS TO BE THE "TOKIN CAPACITOR" BEHIND CPU AS LEFOS SAID.
        • mrsuave001
          • 8
          • philippines
          when i replace e907 l300 toshiba the unit won't boot only power and the voltage across e907 is 4volts is it ok pls help
          • rievax_60
            • May 2012
            • 897
            • australia
            4v would be too high, are you certain? Show us a photo and tell us what parts are used.
            • mrsuave001
              • 8
              • philippines
              it's almost 4volts across e907 when i replace e 907
              • mrsuave001
                • 8
                • philippines
                what should be the voltage across e907 and what circuit does e907 get. its supply
                • mrsuave001
                  • 8
                  • philippines
                  by the before i replace e907 i tried to power it without e907 pls help
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    The NEC Tokin OE907 capacitor filters the Vcore voltage to the CPU. Its usually 0.8v to 1.2v.
                    I really dont think it is possible to have a sustained 4v on the Vcore.
                    • mrsuave001
                      • 8
                      • philippines
                      that's why i need help how to work on it any solution how to repair it e907 is new i replace it already
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        This thread covers the topic, https://www.badcaps.net/forum/showthread.php?t=8991
                        It is a long thread now.
                        • mrsuave001
                          • 8
                          • philippines
                          thank you for responding
                          • viji90
                            • Jul 2017
                            • 22
                            • india
                            hai i need toshiba sattelite A300-1EC bios bin
                            • ganeshcell
                              • Jan 2014
                              • 80
                              • india
                              is your rtc section ok?
                              when not turning on chech 32.768mzh at rtc crystal
                              As u told bios battery was shorten
                              this may leed to rtc failure
                              • lucaszmn
                                by lucaszmn
                                Problem:
                                Initial Findings:
                                • I concluded that the
                                08-12-2025, 03:01 PM
                              • AquaMan Ua
                                Problem with PANASONIC CF53 laptop after changing BIOS settings
                                by AquaMan Ua
                                Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                05-17-2025, 09:40 AM
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • trouble55
                                NEC VersaPro PC-VRT42FBFR22B BIOS problem
                                by trouble55
                                Hi All,
                                [Mother board model]
                                V-VE212(U3E1)
                                [Serial number]
                                24000135PA
                                [BIOS chip model]
                                Macronix MX77L12850F
                                I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
                                I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
                                I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
                                09-19-2024, 01:24 AM
                              • c.daniel
                                Lenovo V310-15IKB weird bios problem...
                                by c.daniel
                                Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                                sn LR09493E
                                MB DAOLV6MB6F0 REV. F
                                The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                                Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                                Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                                08-22-2025, 05:39 AM
