A1466 gone wrong RAM upgrade
  • iMuhtaseb
    • Jan 2017
    • 125
    • Palesine
    hi
    had this 820-00165 2015 MacBook Air with 4GB of RAM.. i thought of upgrading the RAM to 8GB from the pile of donors that I had..
    I took a known-good 4 pairs off of a board and reballed them and put them to my board.. the computer refused to spin or power up.. I found out there was a short on PP1V2_S3.. I mistakenly injected 2 volts into it lol..
    Removed short, fan span but nothing appearing on screen whatsoever..
    I took another 4 pair from another board and put them to my board and still not powering on..
    its consuming half amp on bench PSU.. I can feel the CPU heating up..
    I've also taken the RAMCONFIG into consideration and I've aligned them perfectly and I've even matched my board to the board I had previously..
    I tried PRAM resetting.. its refusing..
    My board was known good and I've tested before.. what could have gone wrong?
  • reformatt
    • Feb 2020
    • 1494
    I'd be checking components around the RAM for solder bridges and movement. Especially in between each chip.
    • iMuhtaseb
      • Jan 2017
      • 125
      • Palesine
      that's a good hint thank you..
      I actually found a short on resistor R2720 MEM_A_CKE<3>.. I removed the associated ram module, reballed it and put it back; short gone but still exhibiting the same thing.. fan spin.. cpu gets hot nothing on screen..
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • duwane
        MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
        by duwane
        Hi All.
        I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
        Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
        After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
        Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
        10-17-2023, 07:48 PM
      • sfernandes
        Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
        by sfernandes
        Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
        What I have done to try to isolate the issue so far:
        The system powers on and stays on with...
        01-23-2023, 06:03 PM
      • survivalbloke
        Need help pinpointing my short on this board (Lenovo) NM-D351
        by survivalbloke
        This is a Lenovo Thinkpad P15s Gen 2 with a board NM-D351. I'm having trouble finding my dead short to ground. I have the area narrowed down after much probing. You'll see in the boardview, there are two coils involved. I removed those coils and verified that that short is not on the mosfet side of those coils. . You'll see an arrangement on both sides of the board of 5 caps and one smaller one to the side. I have removed ALL 12 of these small caps and still have the short. Prior to that I injected at those caps with 1v5a and the short was only drawing 800ma so I could not see anything on thermal....
        03-23-2024, 11:24 AM
      • Stephen
        A2681 MacBook Air 13" Short on board question.
        by Stephen
        The board turned on before hand but it was liquid damaged, I was able to fix some of the issue with the board, but the battery wasn't charging and so we replaced a few caps and still no luck, swapped out 4 batteries to see if the batteries were bad, and they were all good batteries after final testing. I checked for voltage at PPBUS_AON and no voltage was present which was odd, so I went ahead and replaced U5200 with a new chip since this has something to do with the charging issue and power issue. Replaced but no life still, so went ahead and look for shorts and found an odd area that is shorted...
        12-31-2024, 01:16 PM
