Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
  • reessi
    • Jan 2016
    • 334
    With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
    No corrosion any where!
    Tried a replacement power button off ebay and the same.
    Very occasionally it will work with the power button connected!
    Same results with or without the battery.
    Can it be a fault with the Audio board or the mainboard?
    The touch Id assembly connects through the Audio board first then to the Mainboard.
    Flex cable from Audio board is in perfect condition..
    Any ideas what to check?
    I checked reading across both power button tactile switches on the 2 assemblies I have and both the same:
    If RED on Ground side of switch then 1K,
    If BLACK on Ground side then O/C.
    I find that a bit strange? Is there a diode in there?
    I checked the components outside the button on the flex but none connect to the switch apart from Ground obviously.. So they must be for the Touch ID.
    I checked for shorts all over the Audio board but none.
    I'm going to look for the schematics now but I doubt they have the Audio board or Touch/Button Assembly in there.
    Also it is strange that every now again it works! - If there was a short it wouldn't magically un-short itself.
    Many thanks - Simon.
  • gonw
    • Sep 2023
    • United Kingdom
    I've got the same issue, the fault started with the battery indicator not showing charging when plugged in, took it to the apple store and he turned it off during an update now its the boot loop that you have. just started to go through the board view and schematics.
    • mon2
      • Dec 2019
      • 14545
      Apple Store moron that turned it off during an update. There is a reason the procedure notes to not power down / interrupt the installation.
      Try to boot using internet recovery. See if the boot loop stops.
      • reessi
        • Jan 2016
        • 334
        My issue was only related to the power button, sounds you like you had a charging issue and now you have the boot looping because the update was interrupted like mon2 has said.. OS can be corrupted interrupting it..
        After re-installing you can then address the charging issue if still existing..
        I never figured out he issue.. It would always boot loop with the power button so I ordered another for testing and it booted but then I put the old one back in to test and strangely that one worked! I was hoping to meter out the flex on each button to see if a difference but it kept working.
        My friend asked me to leave dis-connected in case it came back, button is not needed for normal operation and he never used the touch id. Macbook self boots up on USB C connection. Button only needed for touch id and forcing off if crashed.. It hasn't crashed so far and you can just wait over night for battery to die if that happened..
        • bouch
          unlock macbook air A1932 2019
          by bouch
          hi
          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
          I need help or information?
          Does anyone have the minat2 activator 1.4 software?
          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
          Thank yo...
          03-12-2025, 10:14 AM
        • nikolayu
          MacBook Air A1932 internet recovery loop
          by nikolayu
          I have A1932 that is going to internet recovery every time.
          i tried nvram and smc reset but it looks that MacBook is not reacting to that.
          i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
          keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
          also won’t open option to boot from usb device.
          and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
          07-22-2025, 02:55 AM
        • modtool
          Macbook Pro A1989 fallen, reboots if touchbar connected
          by modtool
          Hi to all,
          the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
          Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
          11-10-2023, 07:42 AM
        • Featurea
          Macbook air a1932 not working with audio board connected
          by Featurea
          I have macbook air a1932 2018 and it has water damage. Audio connector on motherboard was burned on PPBUS_G3H signal. Without this audio board laptop is working perfectly fine, but of course without sound and touch ID. I changed burned connector, flex cable and audio board. But connecting this all, Mac is not starting, nothing on thermal camera... Do you know what other can be damaged on this signal what can cause this behaviour? Nothing on motherboard looks burned...
          05-25-2022, 07:59 AM
        • Arshad alam4659
          macbook air a1932 sign out of find my
          by Arshad alam4659
          Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
          04-09-2025, 12:37 AM
