MacBook Air A1466 820-00165-A (no power, no light)
  • davidebeatrici
    • Dec 2020
    • 86
    • Italy
    I was brought the computer as it showed no sign of life. Upon opening it I immediately noticed liquid damage in at least one critical spot.
ID:	3293648 Click image for larger version
ID:	3293649 Click image for larger version
    I got rid of J6100 and cleaned/reflowed the other spots. C5126 was broken and as a result it's now missing from the board (should I replace it before investigating further?).
    I didn't take a picture of the bottom as there was nothing to see in particular aside from mild corrosion on R5100, which I cleaned and I also made sure that it measures ~100kΩ.​
    As far as I can tell, everything appears to be in order except for SMC_MANUAL_RST_L being ~0.8V and SMC_RESET_L being ~3.0V. The power adapter is original and I'm sure that it works, but unfortunately I don't have another DC board to test.
    However, if I understood the power-up sequence correctly, there is either a problem on U5000 or U5110 depending on which of the two signals is supposed to be pulled up first.
    Thanks in advance.
  • mon2
    • Dec 2019
    • 14219
    This is a very well documented model. Since the MagSafe light is missing, start with checking if you have the 3v42 power rail.
    If it is absent, check the dual diode that powers the 3v42 regulator.
    The dual diode must pass the higher of the 2 power sources to the 3v42 regulator.
    • davidebeatrici
      • Dec 2020
      • 86
      • Italy
      PP3V42_G3H is 3.428V.
      • reformatt
        • Feb 2020
        • 1412
        Voltages for:
        PPBUS_G3H
        Voltage @ C5001
        PP3V3_S5_AVREF_SMC
        PP1V2_S5_SMC_VDDC
        32khz on SMC_EXTAL/XTAL
        Any corrosion around SMC?
        • davidebeatrici
          • Dec 2020
          • 86
          • Italy
          While inspecting the SMC side I spotted some corrosion around U7400:
          Click image for larger version  Name:	4.jpg Views:	0 Size:	393.8 KB ID:	3293999
          But the U5000 area looks good.
          PPBUS_G3H: 8.65V
          C5001: 3.428V
          PP3V3_S5_AVREF_SMC: 3.322V
          PP1V2_S5_SMC_VDDC: 1.224V
          SMC_EXTAL: ~0.060V
          SMC_XTAL: 0.000V
          I took a look with my thermal camera and the SMC looks quite hot (~57°). Is it expected or a sign of malfunction?
          • mon2
            • Dec 2019
            • 14219
            Was the swamp juice around U7400 cleaned up with IPA?
            The SMC, to me, is way too hot. Wait on other comments but I would at least consider to flux and reflow the component. Perhaps similar issues underneath the component. The SMC is available only from other donor boards.
            • davidebeatrici
              • Dec 2020
              • 86
              • Italy
              The U7400 area is the only spot I haven't cleaned yet as I only noticed it while reporting back here. I will take care of that while reflowing U5000 later today.
              • reformatt
                • Feb 2020
                • 1412
                Bias for Xtal should be 1V. SMC is likely dead. You can swap from a 820-3437 board and reprogram it for 820-00165.
                • davidebeatrici
                  • Dec 2020
                  • 86
                  • Italy
                  How's the reprogramming process? Because I can easily find the chip for sale at a good price online, if it's allowed I can leave links here.
ID:	3294085 Click image for larger version
                  • reformatt
                    • Feb 2020
                    • 1412
                    Donor board is best from eBay etc. Donor boards from China are a lottery, the SMC's pads are often corroded and need scraping, retinning with flux/paste prior to reballing.
                    Use Muerto's SMC tool from GitHub.
                    https://github.com/MuertoGB/SMCTool/releases/tag/v1.0.7
                    • davidebeatrici
                      • Dec 2020
                      • 86
                      • Italy
                      Thank you very much, I'll acquire a replacement SMC and report back here once I get it soldered on.
                      • davidebeatrici
                        • Dec 2020
                        • 86
                        • Italy
                        I cleaned the U7400 area with flux, solder and IPA. Unfortunately R7460 was too corroded to be salvageable, just like C5126​.
                        SMC replacement:
ID:	3301094 Click image for larger version
ID:	3301097 Click image for larger version
ID:	3301100 Click image for larger version
ID:	3301095 Click image for larger version
ID:	3301099 Click image for larger version
ID:	3301096 Click image for larger version
                        SMC_XTAL: 1.145V
                        SMC_XTAL_R: 1.206V
                        But still no light on the charger and no fan spin... what should I check next?
                        • mon2
                          • Dec 2019
                          • 14219
                          Essentially need to revisit each voltage check again.
                          What is the voltage to ground of:
                          PP3V42_G3H​
                          PPBUS_G3H
                          • davidebeatrici
                            • Dec 2020
                            • 86
                            • Italy
                            PP3V42_G3H: 3.427V
                            PPBUS_G3H: 8.23V​
                            • mon2
                              • Dec 2019
                              • 14219
                              1) PPBUS_G3H has not been boosted by the SMC. Should be 8v6 after the SMC kicks in.
                              2) Confirm the voltage to ground of the SMBUS pins used by the PPBUS_G3H regulator.
                              Check:
                              SMBUS_SMC_5_G3_SCL
                              SMBUS_SMC_5_G3_SDA
                              3) Also review this flow chart:
                              G3 to S3 State for Ivy Bridge Haswell and Broadwell - LogiWiki
                              • davidebeatrici
                                • Dec 2020
                                • 86
                                • Italy
                                Thank your for the link.
                                Both SMBUS_SMC_5_G3_SCL and SMBUS_SMC_5_G3_SDA are oscillating between 3.396V and 3.415V. I'm assuming it's why the SMC is not boosting PPBUS_G3H, as according to the flow chart the voltage should be 3.42V.
                                Could U7100 be acting up?
                                • mon2
                                  • Dec 2019
                                  • 14219
                                  Both are pulsing lines since they are communicating using this SMBUS / I2C interface. So SCL and SDA lines will be oscillating high / low to suit and the meter cannot capture the true movement of the signals. Suspecting this to be ok since close to 3v42. Continue to check the flow chart for other possible issues. Was the SMC a known good device? The part contains internal firmware.
                                  • davidebeatrici
                                    • Dec 2020
                                    • 86
                                    • Italy
                                    Yeah, I expected the lines to be oscillating but didn't know whether the voltage range was acceptable.
                                    I'm going to check the other steps in the flow chart and report back. The SMC was sold as "new"... no idea where it actually comes from.
                                    • mon2
                                      • Dec 2019
                                      • 14219
                                      What is the voltage to ground of SMC_RESET_L signal?
                                      Also, review this thread:
                                      Macbook A1466 820-00165 No Power. PPBUS_G3H is at 8.2V | Rossmanngroup Forums
                                      • davidebeatrici
                                        • Dec 2020
                                        • 86
                                        • Italy
                                        I checked all steps of the flow chart until the one that "fails". Anomalies I found:
                                        PP3V2_S5_AVREF_SMC: 3.322V
                                        SMC_LSOC_RST_L: 3.226V
                                        SMC_RESET_L: 3.062V
                                        R5100 went out of spec: it now measures ~85kΩ. What I don't understand is how it's dropping voltage, I'm assuming I don't see it on the thermal camera because the passing current is very low.
                                        Click image for larger version  Name:	thermal_overview.jpg Views:	0 Size:	801.6 KB ID:	3301195
                                        That is, unless I misunderstood the circuit. The way I'm reading it is: SMC_RESET_L is connected to PP3V42_G3H through a resistor (R5100).
                                        • jheunne
                                          A1466 macbook no boot green to orange light help
                                          by jheunne
                                          i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                                          in first image there is 0v out for lcd
                                          https://ibb.co/5XppmpkH
                                          in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                                          https://ibb.co/fdJkbJs8
                                          06-10-2025, 10:52 PM
                                        • sherifu
                                          Macbook Air A1466 Emc 3178 No light charger after spilling liquid
                                          by sherifu
                                          Hello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking...
                                          03-26-2024, 04:54 PM
                                        • sircastor
                                          Macbook Air A1466 No light on charger
                                          by sircastor
                                          I have a MacBook Air 2015 (820-00165-02) that had some liquid damage. It was working for a while only on Adapter power, but that stopped working. Thunderbolt (external display) did not work. There was a bit of corrosion on the board, and I've cleaned that up. The adapter light does not turn on when I plug it in.
                                          PP3v42_G3H: 3.42V
                                          PPBUS_G3H: 0V
                                          PPDCIN_G3H: 16.4V
                                          PPDCIN_G3H_INRUSH: 0V
                                          A lot of this is new to me, but following the schematic, I think that Q7180 is not producing the PPDCIN_G3H_INRUSH voltage, which in turn drives...
                                          02-20-2024, 02:42 PM
                                        • joeoffice12
                                          MacBook Air (2017, A1466, No power/orange-green light on)
                                          by joeoffice12
                                          I have a 13 inch MacBook Air 2017 that does not show any life, however, there is activity from the MagSafe light going from green to orange and staying. Normally, this battery works perfectly fine and it can actually charge the battery as if I were to leave it alone it would change to just green, however, this thing does not boot up at all, I was told the computer was at 30% and then it randomly shut off.
                                          Some voltages:
                                          PPBUS_G3H - 8.5V
                                          SMC_PM_G2_EN - 3.42V
                                          PP3V3_S5 - 3.32V
                                          PP3V42_G3H - 3.42V
                                          PPDCIN_G3H - 15.18V
                                          PP5V_S5 - 5.04V
                                          PP3V3_S5_REG_R...
                                          12-15-2023, 04:00 PM
                                        • GB1999
                                          Macbook Air a1466 820-00165-a (No power , have orange light)
                                          by GB1999
                                          Hi there i have a Macbook Air A1466 board number 820-00165-A. No power, and has Orange light when plug in to charger. SMC is working and the Fuse is good. Found a Short and removed. But still there is short on mosfet. The short leading to Capacitors near Processor.
                                          - 2 Mosfet Near The Processor Is Shorted. (Already Tried Injecting 1V, draining 0.07A) Unable to shop the shorted area. Marked Blue.
                                          - Already Checked Big Capacitor below the processor. (Good Capacitor) Marked Blue.
                                          - Found a short and solved the issue. ( Red marked Big Cap)
                                          Anyone...
                                          04-09-2023, 12:24 PM
