Macbook Air A1466 Emc 3178 No light charger after spilling liquid
  • sherifu
    • Mar 2024
    • 8
    • România
    Hello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking too good) but i need values, i m a beginner and i can t find them in schematics. If You can help me i would be gratefull. Please don t tell me to go to a repair shop because i don t want to spend hundreds of dollars for something which it s not impossible to do and which i can solve with a little help plus i want to learn new stuff.Thank you in advance!
  • mon2
    • 14713
    Welcome.
    The large chip is known as the SMC controller.
    Go to the schematics forum on this website and download the schematic and the board view file for this model (820-00165) of the logic board.
    From the board view file, zoom in on the same section of the logic board. Then click on the parts which are suspects. The file will highlight the part and its value/size. Post any questions you may have.
    • sherifu
      • Mar 2024
      • 8
      • România
      I have tried before writing this post but all i get is the resistor numbers,no values.
      1.C5002
      2.C5007
      3.C5008
      4.R5177
      5.R5178
      • mon2
        • 14713
        The results will vary with how well the board view file was built.
        Now that you know the part index, open the schematics and search for that same R or C part to learn the full details. For example, search for capacitor C1, etc.
        • reformatt
          • Feb 2020
          • 1533
          FlexBV cross references the boardview and schematic together (provided they are same names, just different extensions). Don't know if that is offered in the free version that Paul has out. Just select the component and select search and it's highlighted in the PDF. Saves heaps of time.
          With liquid damage on most MAC boards, you have clusters of corroded components. It's pretty time consuming to individually select and replace each one, hence why we just swap components en masse from donor boards. Often I have to remove, clean up the pads by scraping a little, re-tin, and transplant from a donor. There are boards available from China that drilled with CPU, RAM missing however I prefer non-functional boards from eBay. Most are easily fixed BTW, and at least aren't corroded to hell like the ones from Aliexpress.
          Those components are all 0201 size.
          C5002 = 1uf
          C5007, C5008 = 0.1uf
          R5177, R5178 = 10k
          If you have liquid damage in this area, this often gets under the SMC as well. Often creates intermittent issues.
          • sherifu
            • Mar 2024
            • 8
            • România
            Thank you very much sir!
            • Sergio Kub
              MAcbook Air A1466 EMC 3178 - 2017 Boot
              by Sergio Kub
              Could someone help me?
              I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
              Could it be the BIOS?
              07-08-2025, 04:41 PM
            • Sergio Kub
              Macbook Air A1466 EMC 3178 - 2017 Boot
              by Sergio Kub
              07-08-2025, 04:12 PM
            • dimis1975
              Macbook A1466 2014 not charging with macsafe 2 charger
              by dimis1975
              I have a macboook air a1466 that stopped charging the battery.
              BAT PINS: with or without ADAPTER IN
              1- GND
              2- GND
              3- GND
              4-0V sense pin
              5-3.42V
              6-3.42V
              7- 8.4V
              8- 8.4V
              9- 8.4V
              AC Adapter plugged in: after a lot of of hours some times start charging
              No BAT Connected- Green to Orange
              AC Adapter plugged in: BAT Connected- no light
              The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
              Any ideas what’s wrong please?...
              08-05-2025, 03:43 AM
            • echothegamer
              Macbook A1466 dies when charger disconnected
              by echothegamer
              Hello all,
              Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
              Details:
              Macbook 13' A1466
              Board (820-3209-A)
              Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
              Pictures below of Boardview and schematic...
              I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
              It's an older model and it is very likely that battery has become...
              10-28-2023, 12:00 PM
            • BMCappelletti
              Macbook Air A1466 EMC 3178 missing power and liquid damaged
              by BMCappelletti
              Hi everyone.
              Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
              Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....
              04-15-2024, 01:24 PM
