MacBook Air A1466 820-00165-A (no power, no light)
  • reformatt
    • Feb 2020
    • 1495
    You can remove it yourself.
    https://www.badcaps.net/forum/troubl...ac-efi-toolkit
    • jheunne
      A1466 macbook no boot green to orange light help
      by jheunne
      i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
      in first image there is 0v out for lcd
      https://ibb.co/5XppmpkH
      in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
      https://ibb.co/fdJkbJs8
      06-10-2025, 10:52 PM
    • sherifu
      Macbook Air A1466 Emc 3178 No light charger after spilling liquid
      by sherifu
      Hello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking...
      03-26-2024, 04:54 PM
    • sircastor
      Macbook Air A1466 No light on charger
      by sircastor
      I have a MacBook Air 2015 (820-00165-02) that had some liquid damage. It was working for a while only on Adapter power, but that stopped working. Thunderbolt (external display) did not work. There was a bit of corrosion on the board, and I've cleaned that up. The adapter light does not turn on when I plug it in.
      PP3v42_G3H: 3.42V
      PPBUS_G3H: 0V
      PPDCIN_G3H: 16.4V
      PPDCIN_G3H_INRUSH: 0V
      A lot of this is new to me, but following the schematic, I think that Q7180 is not producing the PPDCIN_G3H_INRUSH voltage, which in turn drives...
      02-20-2024, 02:42 PM
    • joeoffice12
      MacBook Air (2017, A1466, No power/orange-green light on)
      by joeoffice12
      I have a 13 inch MacBook Air 2017 that does not show any life, however, there is activity from the MagSafe light going from green to orange and staying. Normally, this battery works perfectly fine and it can actually charge the battery as if I were to leave it alone it would change to just green, however, this thing does not boot up at all, I was told the computer was at 30% and then it randomly shut off.
      Some voltages:
      PPBUS_G3H - 8.5V
      SMC_PM_G2_EN - 3.42V
      PP3V3_S5 - 3.32V
      PP3V42_G3H - 3.42V
      PPDCIN_G3H - 15.18V
      PP5V_S5 - 5.04V
      PP3V3_S5_REG_R...
      12-15-2023, 04:00 PM
    • GB1999
      Macbook Air a1466 820-00165-a (No power , have orange light)
      by GB1999
      Hi there i have a Macbook Air A1466 board number 820-00165-A. No power, and has Orange light when plug in to charger. SMC is working and the Fuse is good. Found a Short and removed. But still there is short on mosfet. The short leading to Capacitors near Processor.
      - 2 Mosfet Near The Processor Is Shorted. (Already Tried Injecting 1V, draining 0.07A) Unable to shop the shorted area. Marked Blue.
      - Already Checked Big Capacitor below the processor. (Good Capacitor) Marked Blue.
      - Found a short and solved the issue. ( Red marked Big Cap)
      Anyone...
      04-09-2023, 12:24 PM
