Macbook Air A1466 No light on charger
  • sircastor
    • Sep 2022
    • 10
    I have a MacBook Air 2015 (820-00165-02) that had some liquid damage. It was working for a while only on Adapter power, but that stopped working. Thunderbolt (external display) did not work. There was a bit of corrosion on the board, and I've cleaned that up. The adapter light does not turn on when I plug it in.
    PP3v42_G3H: 3.42V
    PPBUS_G3H: 0V
    PPDCIN_G3H: 16.4V
    PPDCIN_G3H_INRUSH: 0V
    A lot of this is new to me, but following the schematic, I think that Q7180 is not producing the PPDCIN_G3H_INRUSH voltage, which in turn drives Q7130 to produce the PPBUS_G3 voltage. So my idea is to replace Q7180. My hesitancy (other than trying to find a replacement part) is that there might be some short somewhere else that damaged Q7180 in the first place.
    There were a few spots of visible corrosion when I first got the board:
    1. Where the wireless network card screws down, right next to D7005
    2. To the Upper Right side of the SMC (U5000) near Y5110 and U3510
    3. Around U3210
    4. And around U3220 (Thunderbolt control)
    I don't have a donor board to work off of. I'm sure I could get one off of ebay for relatively cheap, but then I risk just getting a board with components that also don't work. Any recommendations?
  • mon2
    • 14508
    Remove all power. Meter in resistance mode. Measure the resistane to ground of PPBUS_G3H @ fuse F7140 (check both sides of this fuse). Post your measurements.
    • sircastor
      • Sep 2022
      • 10
      I'm not particularly confident about these measurements. With a probe on ground (The shielding on the magsafe connector) and the other probe on either side of the fuse, I get the following readings:
      PPBUS_G3H: ~3MOhm
      PPVBAT_G3H_CHGR_REG: ~35KOhm.
      However, in both cases the values roll up and down - I was really not able to get a reliable reading there. This makes me think I totally misunderstood what you were asking for - or the appropriate way to do it.
      For what it's worth, the resistance on the fuse is negligible, but not infinite, making me think that it's still in-tact.
      • mon2
        • 14508
        Suggest to use the negative side of a polarized tantalum (black body and rectangular in shape) capacitor for the ground.
        Short the meter probes = should be a similar resistance across a fuse that is not blown.
        • sircastor
          • Sep 2022
          • 10
          Thank you, that was very helpful.
          Either side of the fuse resulted in 0.3Ohm - it looks like it not blown.
          • kevingill
            • Jun 2013
            • 152
            • England
            You'll need to get hold of a parts board if you're serious about repairing this. Otherwise you'll be paying more and spend your time waiting for parts.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              If resistance to GND on both pads of F7140 is 0.3 Ohms,then clearly PPBUS_G3H is shorted.
              De solder the fuse and measure resistance to GND on both PCB pads again. One side will show high resistance and other side(system side) will show short To GND.
              You need to inject 1V/5A on the shorted side and very likely tantalum cap near cpu will heat up.
              • sircastor
                • Sep 2022
                • 10
                This made me look at the Tantalum caps around the board to see if any of them were obviously blown or having trouble. They look okay, but I did notice some corrosion under the microscope that I hadn't seen before around C7140, C141, and C7143. I'll get out my hot air gun this weekend and take off the fuse as you suggest and see if that provides further clues.
                I've got a parts board on the way to help me replace bad components.
                And thank you!
                • sircastor
                  • Sep 2022
                  • 10
                  Allright, I successfully got the fuse off (It was a struggle. All the youtubers make Hot air look like a cakewalk) and attempted to inject power (1V 5A from my Benchtop Power supply) and did not have any success. According to the PSU, it was drawing no current. I felt around the tantalum capacitors, searching for one that was heating up, but didn't find anything specific.
                  To be clear, I had my ground wire attached to a screw hole (easy to access ground) and the voltage wire on the PPBUS_G3H pin of the fuse footprint.
                  What can I look for next?
                  • kevingill
                    • Jun 2013
                    • 152
                    • England
                    With the fuse removed, do you get a voltage on pin 1 of F7140?
                    If not, I'd look at checking/replacing U7100
                    • sircastor
                      • Sep 2022
                      • 10
                      Are we talking about injecting voltage or through the normal power input?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Share resistance to GND on both pads of F7140 while fuse is removed. No power attached while measuring.
                        • dimis1975
                          Macbook A1466 2014 not charging with macsafe 2 charger
                          by dimis1975
                          I have a macboook air a1466 that stopped charging the battery.
                          BAT PINS: with or without ADAPTER IN
                          1- GND
                          2- GND
                          3- GND
                          4-0V sense pin
                          5-3.42V
                          6-3.42V
                          7- 8.4V
                          8- 8.4V
                          9- 8.4V
                          AC Adapter plugged in: after a lot of of hours some times start charging
                          No BAT Connected- Green to Orange
                          AC Adapter plugged in: BAT Connected- no light
                          The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
                          Any ideas what’s wrong please?...
                          08-05-2025, 03:43 AM
                        • echothegamer
                          Macbook A1466 dies when charger disconnected
                          by echothegamer
                          Hello all,
                          Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                          Details:
                          Macbook 13' A1466
                          Board (820-3209-A)
                          Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                          Pictures below of Boardview and schematic...
                          I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                          It's an older model and it is very likely that battery has become...
                          10-28-2023, 12:00 PM
                        • sherifu
                          Macbook Air A1466 Emc 3178 No light charger after spilling liquid
                          by sherifu
                          Hello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking...
                          03-26-2024, 04:54 PM
                        • Instafixx
                          Macbook A1466 Maybe Q7180
                          by Instafixx
                          Namaste.
                          I have a Macbook A1466 with history of liquid spill and repair. The issue currently is that
                          With Battery Connected
                          No Green/Orange Light
                          PPBUS_G3H at 8V.
                          Fan Spins but no Boot.
                          Without Battery Connected
                          Green/Orange Light.
                          PPBUS_G3H is at 8.6V.
                          Machine boots after sometime. Apple Logo appears, the loading bar comes to 50% and the machine goes off.
                          Is it a Q7180 issue ??
                          07-01-2023, 03:12 AM
                        • psdavid65
                          Macbook Air A1466 820-3437-B Booting Problem
                          by psdavid65
                          I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                          06-20-2024, 12:27 AM
