HP DV7-1110ed Num lock
  • vinkos
    • Jul 2013
    • 51
    • Netherlands
    Halo ,
    I do have problem with not working num lock by this laptop.(no light also)
    I did everything i found on the net but no success!
    Before i did reprogram bios(with EZP2010 progg.) and i notice that serial number of laptop has gone .
    Bios do not see it any longer.I think this has something to do with it
    but don,t know what?
    Please ,any idea to help !
  • dj_ricoh
    • 2073
    Re: HP DV7-1110ed Num lock
    they change the mobo!
    its not the first time i saw that thing happen
    try to find the code for the mobo and then go for a bios and reprogram.
    CASE ok mobo (not original) not the same model
    • marcellodj
      • Nov 2010
      • 99
      google for hp dmi tools; is used to write in firmware sn of machine, keyboard area, os installed and so on.
      • vinkos
        • Jul 2013
        • 51
        • Netherlands
        I solved my problem after long search !
        I found HP DMI TOOLKIT(modified) there lot of them on net so was not such
        easy to take right one who work with DV7-1110ed.
        With this tool i put DMI information such as serial number, version number, back in bios and now laptop work fine again.
        So thank you very much for support !
        I did loose a lot of time but ........
        • ry x hunter
          • Jun 2013
          • 184
          • philippines
          sir what is the exact problem of your laptop? ist no power? or no display only? can u give the instruction how you solve the problem? thank u sir...
          • vinkos
            • Jul 2013
            • 51
            • Netherlands
            Problem?
            Num lock did not work on my key board (complete).
            I did take bios chip away from motherboard to reprogram it.
            Somehow motherboard serial number etc. was lost and that
            gave such a problem.
            Whenever i start laptop i got short massage on screen of missing
            serial number , pressing F10 and coming in bios on place of serial number
            was nothing.
            Than i start to look for a way to wrote it back in bios.
            Finely with success .
            Boot able memory stick plus HP DMI TOOLKIT(modified just found via google) plus serial number from back of laptop and i got serial
            number back in the bios and keyboard now working as it should !
            • envym
              MacBook Pro 2018 with Activation Lock
              by envym
              Hi everyone!
              I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
              I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
              06-27-2025, 08:54 AM
            • ArtMov
              [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
              by ArtMov
              Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
              1. I made overclocking lock disabled the default in amibcp
              2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
              03-31-2023, 01:30 PM
            • stormanimal83
              Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
              by stormanimal83
              i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
              08-04-2024, 01:47 AM
            • Kiwi Viking
              HP Elitebook 855 G8 all of a sudden does not power on. 7 flashes of Caps lock and Number lock prod ID 4X5S2PA#ABG
              by Kiwi Viking
              HP Elitebook 855 G8
              Product ID:4X5S2PA#ABG
              Motherboard M53301-601.
              Hi Gurus, I am wondering if someone might be able to help. I purchased recently this used computer that otherwise looks in mint condition. I worked for 1 week, until one morning I shut down the computer using the power off commands in windows. There was no warranty. This was purchased for my teenager for use at school.
              When I went to start the computer up in the afternoon, all the keys lit, but the computer didn't POST. Then the next thing I tried (pressing the power button) resulted in only the...
              03-01-2025, 01:05 AM
            • dark84
              Pioneer vsx920 lock
              by dark84
              Hi. Sorry because my bad english. I bought a receiver (vsx-920). If i plug the unit in the ac outlet, i hear that a relay clicks, hdmi led blinks, after relay click again. Then i power up the unit. Unit is powering on. But if i press any button or rotate input selector or volume on the screen write PANEL LOCK. I able to use the main on/off and the zone on/off. Anything else is PANEL LOCK. I have remote, but no reaction from unit if i press any button on remote. Yet i searched internet and found a software or via telnet i am able to disable the key lock and the remote lock. But to use software...
              12-13-2021, 08:46 AM
