HP DV7-1110ed Num lock
    Halo ,
    I do have problem with not working num lock by this laptop.(no light also)
    I did everything i found on the net but no success!
    Before i did reprogram bios(with EZP2010 progg.) and i notice that serial number of laptop has gone .
    Bios do not see it any longer.I think this has something to do with it
    but don,t know what?
    Please ,any idea to help !
    Re: HP DV7-1110ed Num lock
    they change the mobo!
    its not the first time i saw that thing happen
    try to find the code for the mobo and then go for a bios and reprogram.
    CASE ok mobo (not original) not the same model
      google for hp dmi tools; is used to write in firmware sn of machine, keyboard area, os installed and so on.
        I solved my problem after long search !
        I found HP DMI TOOLKIT(modified) there lot of them on net so was not such
        easy to take right one who work with DV7-1110ed.
        With this tool i put DMI information such as serial number, version number, back in bios and now laptop work fine again.
        So thank you very much for support !
        I did loose a lot of time but ........
          sir what is the exact problem of your laptop? ist no power? or no display only? can u give the instruction how you solve the problem? thank u sir...
            Problem?
            Num lock did not work on my key board (complete).
            I did take bios chip away from motherboard to reprogram it.
            Somehow motherboard serial number etc. was lost and that
            gave such a problem.
            Whenever i start laptop i got short massage on screen of missing
            serial number , pressing F10 and coming in bios on place of serial number
            was nothing.
            Than i start to look for a way to wrote it back in bios.
            Finely with success .
            Boot able memory stick plus HP DMI TOOLKIT(modified just found via google) plus serial number from back of laptop and i got serial
            number back in the bios and keyboard now working as it should !
