Where Can I Buy good Macbook Inductors/Coils? I have broken one :(
  • matheus30
    • Apr 2016
    • 27
    • spain
    When I took it out it broke, and I want to get the same one or one of good quality.
    Where can I buy it? On AliExpress they do not indicate the maximum amperages, and on Mouser or TME.EU it is impossible to search without having the exact reference.
    Inductor needed:
    It is the PP5V_G3S Coil of an A2159, 820-01598 (L7670)
    On the front it says: 1R5
    and in the schematic:
    1.5UH - 20% - 12.5A - 0.017Ohm
    PIMB062D-SM
    152S00268
    Can someone tell me where to buy it?
    Thank you so much.​
  • mon2
    • Dec 2019
    • 14240
    Some details of the original:
    Still looking but you require a 7*7*2.4mm (height) inductor that can support 12.5A or more. Some good brands include Bourns and others. Even Cyntec is a good one to use here. So far, in this physical size, the peak current ratings are lower. This may be still ok since this power rail is not consuming such high currents but for a safety marging, higher the better.
    • matheus30
      • Apr 2016
      • 27
      • spain
      I'm looking for online stores, preferably in Europe or Aliexpress, and at the moment I'm not having any luck.
      Here I have a list:
      https://www.digipart.com/part/PIMB062D-6R8MS
      but they are very large wholesalers that I don't think they will sell me 5 or 10 units.
      IF you find a better known equivalent, please tell me.
      Thanks for your time​
      • mon2
        • Dec 2019
        • 14240
        Note that the original board demands a 1R5 = 1.5uH inductance. The digipart search is with a 6R8 = 6.8uH inductance (not the proper replacement).
        Found a suitable match:
        HCMA0703-1R5-R Coiltronics / Eaton | Mouser Canada
        * change the currency to suit your locale
        • matheus30
          • Apr 2016
          • 27
          • spain
          I will buy the parts this week and tell you if it works, thanks for everything.
          • vincelx
            • Mar 2020
            • 7
            • Portugal
            Worst case you can buy the same dead motherboard from Aliexpress, for a coil it should be ok (maybe expensive for just one coil, but components can be reused on other boards later)
            https://www.aliexpress.com/item/1005...Cquery_from%3A
            • mon2
              • Dec 2019
              • 14240
              Personally would suggest to just purchase the inductor. Otherwise, if you really want a donor board, you could probably source a more complete unit on Ebay and perhaps local to you. Look around for 'locked boards' or 'parts only' marked ads. Will check Aliexpress to see if there are options for this inductor. The linked board on Aliexpress is quite expensive.
              • mon2
                • Dec 2019
                • 14240
                10PCS 0420 0520 0530 0630 1/1.5/2.2/3.3/4.7/6.8/10/15/22uh Molding Power Choke Coil SMD Power Integrated Inductors (aliexpress.com)
                0630 = 7 * 7 mm inductor. Order 1.5uH.
                But confirm the peak current of the inductor before placing the order.
                • matheus30
                  • Apr 2016
                  • 27
                  • spain
                  Be careful with this, I have seen comments that the board has arrived EMPTY, without any components
                  I will buy the MOSER one, taking advantage of the fact that I buy things regularly.
                  A lot of Thanks! Really!
                  • envym
                    MacBook Pro 2018 with Activation Lock
                    by envym
                    Hi everyone!
                    I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                    I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                    06-27-2025, 08:54 AM
                  • tobeend
                    Bypass mdm macbook m2 ventura
                    by tobeend
                    1. RESET MACOS WITH IPSW
                    a. Power off MacBook, press and hold the power button to enter Recovery
                    b. Open Disk Utility, remove Macintosh HD
                    c. Reboot, connect to the network to Activate Mac.
                    d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                    d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                    e. Release the other keys, but keep holding the Power key for another 10 seconds
                    f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                    05-26-2023, 07:18 AM
                  • modtool
                    Macbook Pro 14 2021 - A2442 - 820-02098-A - Internal display not turning on but MacOS working good
                    by modtool
                    Dear collegues,
                    the owner of this machine brought it to me saying that suddenly one day the display didn't turn on anymore, he tought that all the machine was damaged but it turned out that the MacOS starts good and stays on, and that connecting it to an external display it works without problems.
                    If you take a look into general settings, you can also see that the internal retina display is recognized as connected by the main board but for an unknown reason it doesn't turn it on.
                    I've tried to put a bright light towards the screen but I can't see anything, any shadows or apple...
                    05-08-2024, 05:50 AM
                  • SarcasticOP
                    General question about MacBook power rails for repair.
                    by SarcasticOP
                    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                    • PPBUS_G3H (12.6V-12.8V)
                      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                    • PP3V42_G3H (3.42V)
                      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                    • PPVRTC_G3H (3.3V)
                      • This
                    12-12-2024, 05:50 PM
                  • obelix24
                    A2941 Macbook air 15” - 5V 0a
                    by obelix24
                    I’m working on one macbook air 15” m2 that was water damaged.
                    keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                    i’ve put macbook in shelf and order new screen so i can fully repair it.
                    Now i got the screen and macbook stays at 5v 0a.
                    i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                    i don’t have schematics so i don’t know where to start can someone help me?...
                    03-27-2025, 01:19 PM
