macbook A1708 820-00840-A
  • mon2
    • Dec 2019
    • 14032
    This rail should be active after the TBT rom has booted.
    Check the other LDO rails on the CD3215:
    PP3V3_UPC_XB_LDO
    PP1V8_UPC_XB_LDOA
    PP1V8_UPC_XB_LDOD
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      PP3V3_UPC_XB_LDO=3.3V
      PP1V8_UPC_XB_LDOA=1.8V
      PP1V8_UPC_XB_LDOD=1.8V
      I don’t understand why it doesn’t switch to 20V
      • mon2
        • Dec 2019
        • 14032
        The cd3215s must be all operational to switch. Check the voltage on each pin of the TBT rom. The TBT rom firmware may be corrupted. There are dumps of the firmware available on this website.
        • PITERPENY
          • Jul 2023
          • 455
          • Ukraine
          Thunderbolt is U2890?
          • PITERPENY
            • Jul 2023
            • 455
            • Ukraine
            Can I get it from another board?
            • PITERPENY
              • Jul 2023
              • 455
              • Ukraine
              #26
              it worked! Mac works! thank you for your help, this is the first time I've encountered such a problem as a non-working thunderbolt!
              • mon2
                • Dec 2019
                • 14032
                Ghetto is about right. Glad to hear of some success for today. Time for another episode of Top Boy (Netflix). Soon I will be able to speak Brit / Jamaican slang...
                • PITERPENY
                  • Jul 2023
                  • 455
                  • Ukraine
                  #28
                  This is wonderful ! good luck with this))
                  • EpicFix
                    MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
                    by EpicFix
                    Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
                    04-08-2025, 09:55 AM
                  • johnbeton
                    Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
                    by johnbeton
                    I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
                    Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
                    This is what I measure so far:
                    Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
                    PPBUS_G3H = 0,79v
                    PPBUS_HS_CPU = 0,79v
                    PPBUS_HS_OTH5V = 0,79v
                    PPBUS_HS_OTH3V3...
                    05-21-2024, 02:06 PM
                  • 24gsm
                    MacBook Pro A1708 install macos fail
                    by 24gsm
                    hi to all
                    i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                    after enter to recovery and format hdd 1to .
                    after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                    can help please
                    Serial Number: FVFXP0U0HV2J
                    Config Code: HV2J
                    Find My Mac: OFF
                    04-16-2025, 03:57 AM
                  • envym
                    MacBook Pro 2018 with Activation Lock
                    by envym
                    Hi everyone!
                    I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                    I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                    06-27-2025, 08:54 AM
                  • AlexVG
                    Macbook A1708 820-00840 not a start
                    by AlexVG
                    Hi everybody
                    I have Macbook A1708 820-00840
                    It goes through all steps to start
                    exclude last steps power PPVCCCPU_S0G and PPVCCGT_S0G
                    Besides, no exchange on
                    CPU_VIDSCLK
                    CPU_VIDSOUT
                    However CPU_PWRGD is OK
                    CPU_PROCHOT is down.
                    I replaced SPI dump from here:
                    https://www.badcaps.net/forum/troubl...n-me-pram-bios
                    Unfortunately did't help me.
                    Would...
                    11-07-2024, 09:05 AM
