macbook A1708 820-00840-A
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    HI. I need help with this board! 5v/0a stable. Replacing the u7000 did not change the situation. Before I move on to replacing the SD3215, maybe there are some tips on what to pay attention
    also need a diagram and boardview
  • mon2
    • Dec 2019
    • 14013
    What is the resistance to ground of PPBUS_G3H ? (no power to the board while testing in resistance mode - only power to the people!)
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      PPBUS_G3H​=0.002v/diod=0.402
      all indicators on the coils are normal and there are no short circuits
      • mon2
        • Dec 2019
        • 14013
        What is the voltage to ground for the following?
        PPVIN_G3H_P3V3G3H
        PP3V3_G3H
        • PITERPENY
          • Jul 2023
          • 455
          • Ukraine
          I replaced the u7000 from the working board again and the results were the same
          PPVIN_G3H_P3V3G3H=4.75V
          PP3V3_G3H​=3.4V
          • mon2
            • Dec 2019
            • 14013
            3v4 is good.
            With no power, check the full path resistance of the current sense resistor on U7000 (ISL9239).
            • PITERPENY
              • Jul 2023
              • 455
              • Ukraine
              all components have a good value within 0.425 to 0.547 in diode mode! Removing f7000 does not affect anything
              • mon2
                • Dec 2019
                • 14013
                Sorry - should have been more specific.
                1) Diode mode testing will only confirm that the I/O pin on the IC is not damaged. Your readings are good to validate this status.
                2) We are after the full path resistance of the current sense circuit so you will need to be in resistance mode on your meter (lowest scale if manual version meter) -> one meter probe on one side of C7020 and other meter probe on other side of this capacitor.
                We are wanting to confirm the start to end resistance which must match the schematic values. This is for the charging circuit current sensing.
                Repeat the same style of testing with C7023 = current loop sensing for the INPUT of this critical power rail.
                PS: Should you not be sleeping?
                Click image for larger version  Name:	current_loop.png Views:	0 Size:	219.7 KB ID:	3268669
                • mon2
                  • Dec 2019
                  • 14013
                  How are you measuring the current draw? Is it with a usb type C meter ?
                  Is the usb c meter a bidirectional type?
                  Since there are valid voltages on the board, the current draw should be > 0 A. Expecting at least a few mA on the current draw.
                  • PITERPENY
                    • Jul 2023
                    • 455
                    • Ukraine
                    mon2 you should work as a consultant on the Rossman forum, otherwise they have a negative attitude towards inexperienced masters like me!
                    I have a lot of work that I'm new to
                    C7023=2.4ohm
                    C7020=2.4ohm
                    • mon2
                      • Dec 2019
                      • 14013
                      These are good measurements. Are you using a usb C meter? Is it bidirectional type ? Does the same tool show a valid current draw on other devices?
                      • PITERPENY
                        • Jul 2023
                        • 455
                        • Ukraine
                        I made a video for you but I don't understand how it works here
                        https://youtube.com/shorts/wzIFIk-VcUI?feature=share
                        • mon2
                          • Dec 2019
                          • 14013
                          Be sure that the USB C paddle board is firmly attached to the mezzanine connector. Even with a single LED as a load - there should be a current draw showing on the meter of a few mA.
                          The default power up voltage on the power adapter is 5 volts and with no load, it will be 0A for the current draw. Check the voltage on the input fuses on the board - do you see 5 volts?
                          Do test the same meter on another type C product to confirm the current draw feature is working.
                          • PITERPENY
                            • Jul 2023
                            • 455
                            • Ukraine
                            The tester works flawlessly, checked!
                            I have no voltage on the F7000 (it is temporarily removed)
                            • mon2
                              • Dec 2019
                              • 14013
                              Check each of the LDO rails on the CD3215 ACE controllers - they must be present. Each CD3215 must be working to allow for the 20V power delivery contract as per the article by @Piernov.
                              CD3215 Bootup Sequence - LogiWiki
                              Confirm the voltage to ground of:
                              SMB_SMC_CHGR_SCL
                              SMB_SMC_CHGR_SDA
                              We must have a valid voltage on PPBUS_G3H to continue. Not shorted?
                              Confirm the DIODE mode readings for the _CC1 and _CC2 pins on each of the USB C port.
                              For example:
                              USBC_XA_CC1
                              USBC_XA_CC2
                              • PITERPENY
                                • Jul 2023
                                • 455
                                • Ukraine
                                Now I will replace the CD 3215 with new ones and write down the results, do you ever sleep?)))) I sleep, you are here, I woke up, you are here))))
                                • PITERPENY
                                  • Jul 2023
                                  • 455
                                  • Ukraine
                                  I replaced it with new CD 3215, no changes.
                                  USBC_XA_CC1=0.567
                                  USBC_XA_CC2=0.569
                                  USBC_XB_CC1=0.566
                                  USBC_XB_CC2=0.569
                                  SMB_SMC_CHGR_SCL=2.6-3.4v unstable
                                  SMB_SMC_CHGR_SDA=2.6-3.4v unstable
                                  • PITERPENY
                                    • Jul 2023
                                    • 455
                                    • Ukraine
                                    PP1V1_UPC_XB_LDO_BMC=0V
                                    • mon2
                                      • Dec 2019
                                      • 14013
                                      This is the CCx power rail for the BMC interface used by the power delivery communication. This power rail will only be active for the side of the USB-C blade that is being used to power the board. Confirm this by checking the LDO_BMC rail for the other side of the same USB-C connector that is being used. One side must offer this LDO rail with 1v1 output.​
                                      • PITERPENY
                                        • Jul 2023
                                        • 455
                                        • Ukraine
                                        I also changed the CD 3215 and still have PP1V1_UPC_XB_LDO_BMC = 0V (in diode mode 0.471)
                                        • EpicFix
                                          MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
                                          by EpicFix
                                          Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
                                          04-08-2025, 09:55 AM
                                        • johnbeton
                                          Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
                                          by johnbeton
                                          I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
                                          Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
                                          This is what I measure so far:
                                          Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
                                          PPBUS_G3H = 0,79v
                                          PPBUS_HS_CPU = 0,79v
                                          PPBUS_HS_OTH5V = 0,79v
                                          PPBUS_HS_OTH3V3...
                                          05-21-2024, 02:06 PM
                                        • 24gsm
                                          MacBook Pro A1708 install macos fail
                                          by 24gsm
                                          hi to all
                                          i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                                          after enter to recovery and format hdd 1to .
                                          after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                                          can help please
                                          Serial Number: FVFXP0U0HV2J
                                          Config Code: HV2J
                                          Find My Mac: OFF
                                          04-16-2025, 03:57 AM
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                        • AlexVG
                                          Macbook A1708 820-00840 not a start
                                          by AlexVG
                                          Hi everybody
                                          I have Macbook A1708 820-00840
                                          It goes through all steps to start
                                          exclude last steps power PPVCCCPU_S0G and PPVCCGT_S0G
                                          Besides, no exchange on
                                          CPU_VIDSCLK
                                          CPU_VIDSOUT
                                          However CPU_PWRGD is OK
                                          CPU_PROCHOT is down.
                                          I replaced SPI dump from here:
                                          https://www.badcaps.net/forum/troubl...n-me-pram-bios
                                          Unfortunately did't help me.
                                          Would...
                                          11-07-2024, 09:05 AM
