MacBook Pro 16" M3 LCD compatibility?
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Has anyone discovered if the M2 LCD works with the M3 board on the 16" I believe these are the same LCD? I know the M1 and M2 work on the 16" but does the 16" M3 LCD work with M2 LCD or M1? Curious if anyone has tried this yet?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Any updates on this? Any experience on these? I may do the check myself but just curious.
    sigpic
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • gabrielA7
      Macbook pro A1706 / Backlight flex cable compatibility
      by gabrielA7
      Hey guys!!
      I’ve got a question here!
      I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
      Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
      Here’s what the bot told me:
      I said to him: “I’m going to install the 821-01229-A.”
      ChatGPT replied:
      Understood — but before you solder or install the 821-01229-A,
      11-11-2025, 03:26 PM
    • daltonjr.
      Macbook a2338 M1 CD3217 chip compatibility
      by daltonjr.
      I have a2338 MacBook with one bad CD3217 chip. Are there any compatible chips on aliexpress that actually work? Or only chip from same motherboard can be used?
      I remember buying one CD3215 for older 15" model on aliexpress and that one worked.
      Thanks!
      03-03-2025, 05:37 AM
    • Flasman90
      Macbook Pro DFU Restore Issues
      by Flasman90
      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
      08-30-2025, 10:27 AM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
