Macbook a2338 M1 CD3217 chip compatibility
  • daltonjr.
    • Jul 2016
    • 50
    • Austria
    I have a2338 MacBook with one bad CD3217 chip. Are there any compatible chips on aliexpress that actually work? Or only chip from same motherboard can be used?
    I remember buying one CD3215 for older 15" model on aliexpress and that one worked.
    Thanks!
  • daltonjr.
    • Jul 2016
    • 50
    • Austria
    Bump 🙄
    • ugamazing
      • Jun 2013
      • 171
      • usa
      You can find good chips there, but you'll also find bad ones. Best to source from a parts board if you can; the 02020 boards can have the controllers replaced individually if you pull from the same model/etc. There are plenty of good sellers on eBay for chips as well!
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • Loki_Fido
        Requesting help identifying chip in Macbook Pro A2485
        by Loki_Fido
        Hi ya folks,
        I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
        It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
        I replaced it and the SSD are fine. No more shorts.
        But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
        But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
        Chip marking...
        08-07-2025, 10:17 PM
      • SSBDADC234
        MacBook Pro 14". The screen DP chip failed.
        by SSBDADC234
        When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
        However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
        Testing the chip pins with a multimeter revealed a short circuit inside the chip.
        Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
        04-19-2024, 08:51 PM
      • Orux
        Macbook Pro M1 A2338 13"
        by Orux
        I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
        I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
        One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
        09-22-2025, 12:54 PM
