A2442 hinge sensor has liqud damage
  • vijayppatel017
    Vijay Patel
    • Dec 2023
    • 4
    • United Kingdom
    A2442 hinge sensor has liquid damage, not possible to repair, is there any alternate?
  • mon2
    • Dec 2019
    • 14633
    https://boards.rossmanngroup.com/thr...-sensor.64047/
    • reformatt
      • Feb 2020
      • 1470
      Previously the fix had been to transplant the IC from the damaged flex to a replacement. However, someone has developed a tool to calibrate replacement angle lid sensors.
      https://notebooknerds.de/en/nerd-tool-1/
      It's 169 euro, but like all good tools, you'll make your money back on that in the first few repairs.
      Also covered in Rossman's video on YT some time ago.
      https://www.youtube.com/watch?v=Lxo6...=LouisRossmann
      • piernov
        • Jan 2016
        • 4437
        • France
        https://logi.wiki/index.php/Macbook_...or_Calibration
        https://github.com/Vladislav98759/Ma...libration-Tool
        • mon2
          • Dec 2019
          • 14633
          This is a cool topic. Did not know about this issue till now. From a brief review, concerned about the programming hardware shared on the referenced logi.wiki.
          The ESP8266 Node MCU board IO voltage vs. the lid angle sensor IO voltage. From the schematics, the lid angle sensor IO voltage is 1v8 for the SPI interface.
          The ESP8266 Node MCU IO voltage appears to be 3v3. A proper interface should either operate the IO pins on the ESP8266 @ 1v8 OR apply a voltage level shifter to allow for 3v3 (Node MCU side) to communicate with the lid angle sensor @ 1v8.
          Only if the lid angle sensor Vcc is permitted to operate @ 3v3, then the Node MCU voltage can remain @ 3v3 for the IO voltage.
          • piernov
            • Jan 2016
            • 4437
            • France
            The sensor should work fine at 3.3V levels when its I/O domain supply is 3.3V. However, it must not be connected to the main logic board during the operation.
            • CapLeaker
              AcuRite 5 in 1 temperature sensor replacement repair
              by CapLeaker
              Got a new victim:
              AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
              A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
              B: stuck at some temperature and maybe updating once in 12 hrs or so.
              Easy solution is to go to AcuRite website and purchase the sensor. Right?...
              04-15-2025, 01:32 PM
            • groomit
              Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
              by groomit
              I just replaced the battery on a Google Pixel 5.
              After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
              Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
              The rubber seal is on again (as mentioned in various suggestions in other forums).
              This smells like a cold or broken solder joint. So I'd like to reflow...
              06-11-2025, 02:21 AM
            • gurj1979
              MacBook Pro 820-01987- condensation damage repaired but has sensor issue
              by gurj1979
              Hi guys.
              Got a customer MBP 2020 which has a dad of corrosion from condensation, resulted in no power at all.
              I replaced the corroded components and repaired the traces. Restored power and now Iccan get to login screen.
              But when the CPU gets warm (not hot) and fan gradually starts spinning faster and then MBP turns off. Pressing power button turns it back on for couple of seconds then it turns off again.
              Seems sensor related, but it won't even let me get as far as running the built-in ASD.
              I can get back to you later with the components...
              08-01-2023, 02:38 PM
            • Gcnewbie
              Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
              by Gcnewbie
              Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
              I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
              My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
              I opened the...
              03-29-2024, 06:55 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
