Toshiba Satellite C850 wont charge battery
  • saxonas
    • Feb 2014
    • 8
    • greece
    Hi guys i really need your help with this!I got this laptop from a friend who asked me to troubleshoot it.
    It doesn't charge the battery.I cant find a specific schematic for the motherboard.There is a schematic in another thread but i cant figure what to test because it is not the same motherboard.
    1) Ac adapter is ok.
    2)Tested with the same adapter of the same model.
    2) battery is ok
    3) The dc port also is ok.
    I tried to check one of the mosfets next to power supply port.
    its the same as this pic shown in this thread : https://www.badcaps.net/forum/showthread.php?t=33704
    the big one gives me 19V from the one side (all pins) but nothing on the other side of the pins.Is that normal? what should i check to figure what is wrong?
    Laptop works fine with battery.Sometimes but not very often, the charging led is flashing like there is a random short.Only once the laptop had a successful charge.I removed everything to check for a short but that didn't work.I would appreciate any help on this! thanks!
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    Re: Toshiba Satellite C850 wont charge battery
    There is a number on the motherboard post that and maybe somebody has correct schematic. you could have an issue with the charging ic. Also have you tried this http://www.speedguide.net/faq_in_q.php?qid=380
    Also you need to verify its a good battery
    • saxonas
      • Feb 2014
      • 8
      • greece
      The battery is ok.Works and charge fine on another toshiba laptop which use the same battery model.Laptop doesnt power on from adapter.I managed to power it from AC adapter 1-2 times for a couple of hours but since then never worked again.
      A work around is to buy a battery charger or visit a friend who has the C855 and charge it .I think it is the charging IC. It doesnt switch to give Voltage to the battery.Motherboard is always at battery state without incoming voltage from adapter.
      • saxonas
        • Feb 2014
        • 8
        • greece
        Here are some photos.The big Mosfet gives me 19v only from its one side(all legs).
        • saxonas
          • Feb 2014
          • 8
          • greece
          What is the ZRZ next to the fuse?Can someone give me a guide how test around the fuse.
          • 3d0
            • Jan 2014
            • 159
            • BiH
            It's more like 2R2, not ZRZ?
            R-standing for resistor, if you could find a schematic I'm sure someone could help.
            Edit: Here's one posted by cyberhack
            Originally posted by cyberhack
            here is the diagram
            • saxonas
              • Feb 2014
              • 8
              • greece
              Yes you are right.Its a resistor.This schematic is different.I think my motherboard is Quanta.
              • athrelia
                • Feb 2014
                • bangladesh
                Please show me a way.......curious.........
                I have also same problem with dell vostro.
                found charging ic burnt. replace with same.
                in display battery recognize.show charge ups and down.
                But battery not charging............why?????
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  check battery side mosfets of charging circuit.
                  • Microbe
                    • Feb 2014
                    • 17
                    • Yemen
                    right spidey,
                    it is either charging mosfets or faulty charging ic which is max8731 in most dell laptops.
                    • cyberhack
                      • Feb 2013
                      • 466
                      • Uk
                      Here is the INVENTEC please the full pcb number
                      • saxonas
                        • Feb 2014
                        • 8
                        • greece
                        Is there a way to make it work only with Ac adapter?can someone help with that?
                        thank you
                        • helderfb
                          • May 2014
                          • 16
                          • portugal
                          change the little FDMC chip, and the battery will charge.
                          • speedster83
                            • Jan 2016
                            • Cyprus
                            I have similar problem, my c850 won't charge or start from power adapter. But can be powered and works from battery if is charged.
                            My motherboard has a label 12146959-01512-69N0ZWM2UA03-01, which probably has different diagram from the one attached on this thread.
                            Also serial is H000052360.
                            Does anyone know where I can find a diagram for this MB?
                            I noticed that an IOR F8707 power mosfet close to power plug do not output 19v (as input) but something close to 0.8-0.9V. Do you thing this is wrong and I found the issue?
                            Another IOR F8707 outputs the same volts on 3 pins and more volts than input on the 4th pin.
                            P.S. I don't have experience on troubleshooting MB, just learned everything from this awesome forum.
                            • nassimhamdi
                              • Feb 2016
                              • 150
                              • algeria
                              where is the schematic???
                              • pravardhan85
                                • Mar 2017
                                • India
                                Hi Guys,
                                My Toshiba Satellite C855-S5194 started to blink the Amber (Orange) LED in charge indication 2 weeks back and in Windows 8.1 battery icon it shows as "plugged in, not charging". The laptop is 4 years old and battery backup was around 1 hour.
                                The laptop boots fine from the AC adapter without battery and the charge indication is steady white light. Laptop also works fine on battery when the AC adapter is removed, but will not charge after AC adapter is connected back.
                                So, i bought new battery at a local store & inserted it to the laptop. The battery charged for 3-5 mins and again started to blink the orange light at charge indication.
                                Now, I got the schematics for this laptop model. But, I don't know which component is giving problems like this.
                                Have anybody experienced this kind of problem and if yes which is the component that I have to replace.
                                Thanks & Regards,
                                PRAVARDHAN U.S
                                Last edited by pravardhan85; 03-29-2017, 06:02 AM. Reason: Missed out some information
                                • techfreak9356
                                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                  by techfreak9356
                                  09-14-2023, 11:10 PM
                                • razenxd
                                  How can I charge that battery pack?
                                  by razenxd
                                  it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                  At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                  Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                  Now, I have noticed a few things.
                                  The "dead" battery, while connected to charger and NOT Charging will...
                                  12-05-2024, 06:11 AM
                                • ruletero
                                  Acer a515-43 low battery charge voltage
                                  by ruletero
                                  Hi
                                  Acer A515-43
                                  LA-H801P
                                  Fail: Does not charge battery, has low voltaje on connector.
                                  Laptop didn't want to turn on, only charge led blinked.
                                  I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                  I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                  Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                  10-24-2022, 02:31 PM
                                  Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                  This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                  09-06-2024, 06:10 AM
                                • Klevjetack
                                  Charge a L19D3PDA battery externally from the laptop
                                  by Klevjetack
                                  Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                  03-05-2024, 07:26 AM
