Have you found the issue? I might also have a very similar issue with A2338, the battery charging sign comes up then the Apple logo comes up for 2-3 sec and shuts back down. can't able to find the issue. I am getting good readings all over the board. A little help would be nice. Thanks!
					A2338
What is the condition of the battery? What is the history of this unit?
Are you using the official or proper rated power adapter?
If available, test with another known good battery. You should be able to find them on Amazon and return it if not required.
What is the USB Type C meter readings for this board? 20V? Current draw?
What is the voltage to ground reading for:
I2C_SMC_PWR_3V3_SCL
I2C_SMC_PWR_3V3_SDA
			by StephenCustomer came in with a board issue, board looks clean, board turns on, he did a software update and he got the infamous Apple boot loop logo. He took it to Apple and Apple said he needed a new board. They attempted to DFU revive restore etc no luck. The board is stuck on the (!) point. I tried DFU myself and no luck. Nothing, board boots up goes into DFU computer turns on with Apple logo when applying the patch and nothing it gets stuck at halfway point and hangs on. I was wondering if anyone has had any experience with this particular issue. Board isn't liquid damage from what I can tell...
Assuming...7 Photos -
			by rouninHi everyone,
I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
🛠 Original Issue
The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
			by bigbadbiosHi,
I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
Your help is GREATLY appreciated. Thanks! -
			by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... - Loading...
