HP G6 strange problem
    hope to get help.
    Random that notebook turn on but no video.
    If remove battery and turn on with ac adapter all work.
    Thank you in advance.
    Re: HP G6 strange problem
    Reflash the bios.
    Check the thermal compound under :-)
    You know just in case
      Originally posted by dj_ricoh View Post
      Reflash the bios.
      Well, about bios is installed last version F.66
      About thermal compound, already replaced.
      The motherboard is an integrated version then without graphic ic dedicated.
        reflow the chipset
          Originally posted by robrock1 View Post
          reflow the chipset
          i dont think is a reflow issue
            Works properly with adapter?
            Post mobo code or link to schematic.
              hi Francisco, here schematic
                well, i seen that:
                - with battery, start but no video
                - with battery and ac adapter, start but no video
                - with ac adapter only, start and work fine.
                  did you try with another battery?
                  i saw a lenovo 3 days ago that freez and shutdown with battery on( batt was fubar).
                  with another(new) was ok.
                  if does the same think with another working batt then you must try a downgrade bios.
                  if that does not work you need to chase the ic charging chip
                    sorry not have another same battery
                      done bios downgrade.
                      at first 3 time seem work. i need to test in the next days.
                      bios version now F.64
                        update... when cold dont work... start but no video... i go to investigate
                          its a bios fault
                            that`s the video !
                            try a reflow
                              Originally posted by alihomee View Post
                              its a bios fault
                              i think no because i done downgrade bios and got same problem.
                              i'll try to reflow chipset
                                Hi Pragmatiko
                                Did you check all secondary suuplies if all they are OK? Like CPU Vcore, GPU core and memory?
                                  tested with another battery and problem is same.
                                  the strange thing is that if i remove battery and start again, it work and video appear.
                                    No video, but you have all secondary lines like 1.8V in RAM, 1.2V GPU, 1.05V CPU core and so on?
                                      i need to check, consider that if i start with ac adapter only, without battery work fine
                                        update, i've seen that when defect is present, VCC_CORE is not present.
