Asus motherboard DABKLGMB8D0 REV D
  • ERRORSYSTEM
    • Dec 2022
    • 9
    • Slovensko
    Hello. On the DABKLGMB8D0 motherboard, the mosfet aon6414al fires for me - on the board, the marking is PQ21. They fired it for me even after the exchange. Can anyone tell me why it does this?
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    remove PQ22 and PQ21 and check the ohmic value
    • ERRORSYSTEM
      • Dec 2022
      • 9
      • Slovensko
      Between 1,2,3 and ground it shows around 7ohm. Between 4 and ground it shows 50ohm.
      Between 5 and ground 113kohm.
      It shows differently with each measurement, sometimes even a pure short between 4 and 1,2,3 contact...
      When measuring, I had both PQ21 and PQ22 selected.
      I can't find PQ20 on the board, I don't have all the diagrams. I've been sitting on this for 4 hours...
      • mon2
        • Dec 2019
        • 14662
        For the posted measurements above, are the mosfets @ PQ21 and PQ22 on the board or off the board? Post a pic of the board if you have it available.
        Schematics and boardview files are available for this model.
        Click image for larger version  Name:	sch1.png Views:	0 Size:	402.1 KB ID:	3205059
        Click image for larger version  Name:	pq20.png Views:	0 Size:	384.3 KB ID:	3205060
        • ERRORSYSTEM
          • Dec 2022
          • 9
          • Slovensko
          The mosfets are off the board. Can you please send me the boardview? I will be very grateful to you.
          • ERRORSYSTEM
            • Dec 2022
            • 9
            • Slovensko
            strange PQ20 is not on the board...
            • ERRORSYSTEM
              • Dec 2022
              • 9
              • Slovensko
              • mon2
                • Dec 2019
                • 14662
                Hi. I believe this mosfet, being a sot-23 package is tiny and is hidden underneath the connector @ CN19. I thought the boardview file is on this forum but yes, can post it. Let me confirm it is not a duplicate first.
                Believe it is the same and also posted here:
                asus DABKLGMB8D0 - Badcaps
                Can you confirm it? What I do not see is the schematic for this model which is also available but locked to my paid sub.
                Are PQ21 and PQ22 on or off the board?
                The posted measurements look very low which indicate a shorted component onboard. Be sure that all power is removed -> meter in resistance mode -> measure the resistance to ground of source (1-2-3); then gate (4) then drain (5-6-7-8) for each of these DCin mosfets. You should not have a low resistance to ground on either of these measurements.
                • ERRORSYSTEM
                  • Dec 2022
                  • 9
                  • Slovensko
                  PQ21 and PQ22 are off the PCB.
                  The measured values ​​on the board are PQ21:
                  - the resistance to ground on 1,2,3 is now 7ohm
                  - the resistance to ground and Gate is infinite
                  - the resistance to ground and Drain is 113k
                  The measured values ​​on the board are PQ22:
                  -resistance to ground on 1,2,3 is now 9ohm
                  - resistance to ground and Gate is infinite
                  - resistance to ground and Drain is infinite
                  It is possible that there is a short circuit on the board, because I am measuring different values...
                  • glovecaps
                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                    by glovecaps
                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                    11-25-2024, 04:23 PM
                  • dhenion
                    Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                    by dhenion
                    I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                    The original board was:
                    ASUS X510UNR REV 3.0 A
                    The replacement board is:
                    ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                    It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                    01-30-2024, 01:45 PM
                    ASUS P5GC-MX motherboard recap
                    by momaka
                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                    So here is what the motherboard looked like with its original caps:
                    CPU VRM area up close…...
                    01-27-2021, 11:59 PM
                  • MakNCheese
                    ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                    by MakNCheese
                    I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                    Symptoms:
                    • Severe lag across the system, including BIOS navigation.
                    • Slow boot times and unresponsive performance in Windows.
                    • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                    • No error messages or BSODs, just extreme sluggishness.
                    What I've Tried:
                    • Replaced
                    06-04-2025, 12:48 AM
                  • EvazX
                    ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                    by EvazX
                    I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                    Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                    For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                    However, after some time, the replacement motherboard...
                    08-25-2025, 06:09 PM
