Inspiron 6000 no backlight
  • crdz66
    • Nov 2012
    • 242
    Hello Fellas
    I need your value opinion on this.
    I have a Dell Inspiron 6000 with backlight problem, I guess.
    On this laptop I have a
    LTN154X2-L02 Screen.
    I replace the inverter(A-15B07001-64F-6084) "Suppose for inspiron 6000"
    I get from ebay a inverter tester (blue ones) and with the inverter tester I was capable for test the lamps and was ok.
    I try with another screens and the backlight was ok (with the inverter from ebay)
    On the original screen I have a visual video when I use a home lamp.
    External Monitor show everything good.
    Questions?
    1. My lcd screen is compatible with this inverter? How can I know?
    2. My Lvds cable can be bad?
    3. Gpu provide the video to screen and the external monitor too? or Northbr...
    Thanks an advance
  • dj_ricoh
    • 2073
    • uk
    Re: Inspiron 6000 no backlight
    if you did try with another screen and saw that it light up then the screen its the problem.
    dell its know for its used that goes bad(lamps)
    • alihomee
      • Dec 2012
      • 1575
      • malaysia
      just change the lcd screen
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        change ccfl.
        • dj_ricoh
          • 2073
          • uk
          i swap this weekend 2 for me ^^
          i had one with red tone from a dell ( old lamps) and one with no backlight(faulty lamps)
          i have 0.5Mx0.5m of broken screens just for this type of job.
          find a broken screen and swap the lamps
          • artois7
            • Mar 2011
            • 159
            New CCFL tubes are approx. £1.50 online anyway in my experience. Never been worth using an old one for me.
            • dj_ricoh
              • 2073
              • uk
              it depends ! if its bright white its ok.
              when you open and see a dark tone near the end yeee it was use well if its only a little .
              it will be just fine for a job like this
              • crdz66
                • Nov 2012
                • 242
                Thanks to everyone
                I going to try to get a new lcd screen
                • HTR-Informatique
                  Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                  by HTR-Informatique
                  YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                  I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                  On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                  I also changed the screen because the PC fell and the screen was broken.
                  I changed the battery with a new and original battery.
                  I also had corrosion/oxidation on the...
                  02-09-2025, 06:51 AM
                • turmix
                  AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                  by turmix
                  Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                  The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                  At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                  During another reassembly, I made a mistake, and...
                  01-29-2024, 03:48 AM
                • trepachka
                  HP Probook 450 G8 Boardview+Schematics - screen backlight issue
                  by trepachka
                  I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
                  Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
                  Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
                  03-16-2024, 12:32 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • RetroComputingGrotto
                  LG 42LN540V LED Backlight Flickering After Replacement When Connecting The Screen
                  by RetroComputingGrotto
                  This TV has been on the wall in our reception area for around 10 years and the other day the backlight failed. You could see a feint picture so we knew the screen was OK. I took the TV apart to get to the failed backlight and inject voltage in to each half of the LED strips to identify which ones had failed and 4 needed replacing. I ordered a set off of Amazon and they arrived the next day.
                  On fitting the new LED strips I plugged in the TV was blinded by the light!!
                  It was only when I partially put it all back together (including the screen) that...
                  10-23-2024, 04:17 AM
