MS-16J91 help in identifying a component
  • mon2
    • 14659
    Your ACDET voltage is good. Most likely the ACOK signal is attempting to output a logic high but unable to do so due to the missing +3VALW ldo rail.
    At this time, do not believe the 2nd mosfet should be on yet it is passing the +19v onto the logic board. However, even with this leakage voltage, the +3VALW is missing and is required.
    From where do you plan to purchase the parts for the repair? For sure you need to replace this regulator. Suggest also the dcin mosfets. Each are inexpensive so buy spares.
    do you have hot air tools? Flux? Ipa alcohol? Tweezers? Practice on a donor or dead board to remove parts. Then flux and replace the 2nd dcin mosfet.
    power up again to check if the new mosfet remains off since gate voltage is too high to be on.
    then review location of pin #1 on this square regulator (qfn package = quad flat pack = pins on each of the 4 sides). Flux it well + hot air with low pressure to not lose the other parts. Then lift the part with a gentle nudge of the tweezers. If you rush it or too much heat then the board will burn or the pcb tracks will lift.
    • Fronczek
      • Jan 2024
      • 33
      • Poland
      Alright, got it! I have all of these tools available. I purchased the buck controller from a shop closer to my location, apparently they get their supply from Mouser. Should I also purchase the exact mosfet or will one from a donor board suffice?
      • mon2
        • 14659
        A donor mosfet can work but criteria is as :
        1) same type so p-channel
        2) same size- check the dimensions in the datasheet of each part
        3) same or higher source / drain voltage of 30 volts.
        4) same or higher rated current as the original
        • Fronczek
          • Jan 2024
          • 33
          • Poland
          All of it will be in the datasheet right? The regulator arrives on Tuesday so see you then!
          • piernov
            • Jan 2016
            • 4439
            • France
            Originally posted by mon2
            Mosfet PQ8:
            19.4V on source
            19.9V on drain
            19V on gate​
            If the gate is at the same voltage as the source / drain pins then the mosfet should be OFF. Perhaps this mosfet is defective and needs to be replaced. PQ8 = P-channel mosfet so for this mosfet to enable, the GATE voltage must be LOWER than the source / drain voltages yet there is voltage on each side of the mosfet.
            Current is flowing through body diode of MOSFET, as seen by the diode voltage drop from source to drain. Gate not pulled low because ACOK not pulled up because +3.3VALW is missing since 3V/5V regulator has been damaged.
            If MOSFET wasn't letting current through without being turned on, there would be no way to power the 3.3V/5V circuit so no way to turn on the MOSFET.
            There was no need to work on any of these circuits if the voltages were good, and as always the first thing in a "no display" situation is to clarify if it's "no backlight", "no image" or "no POST" or even "not turning on".
            • Fronczek
              • Jan 2024
              • 33
              • Poland
              #26
              Alright, I replaced the regulator and my ALW lines are back.
              Piernov, I'm not trying to just get an answer to my issue and be gone, I want to actually learn how to check circuits.
              The issue is that it's not giving image nor backlight. It's not detected by bios nor OS, and we already established that it's an issue with the motherboard not the LCD screen.
              • chth96
                by chth96
                03-09-2024, 10:03 PM
                12-31-2023, 06:04 AM
              • jorpec
                by jorpec
                Hi
                Thnaks
                01-23-2023, 10:37 AM
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • mkdj
                Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                by mkdj
                Dear all,
                I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                Both N-Channel Mosfets: nothing odd
                P-Channel MOSFET number 1:
                source - drain : 117 kOhm
                source - gate: 96 Ohm
                gate - drain: 117 kOhm
                P-Channel MOSFET...
                08-20-2025, 06:08 AM
