A2445 MacBook Pro 16" M1 Max issue
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    Found the short on the board, it is the APL 1098 chip. Chip is shorted, fixed all shorts and now power and found the short at the chip (spiking to around 150 degrees) big chip non the less, I do have a good donor board with a good chip, my question is what does this chip do? Is it serialized to the board if I replace it will it not turn on even if its a good chip. Please let me know. We are fixing a computer for data recovery and we found the main issue (this chip has the apple logo)
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mikay786
    • Aug 2014
    • 765
    Seems to be a power management ic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 676
      So do you believe these chips are serialized to the board? Would a donor board solve this issue, this seems to be a worry about investing into this chip. I know you cannot buy these chips on the market only way to get one is to buy an activation locked board that is useless basically but it works and that is how we verify the chip is good, however these chips are so damn fragile :/
      sigpic
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • Loki_Fido
        Requesting help identifying chip in Macbook Pro A2485
        by Loki_Fido
        Hi ya folks,
        I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
        It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
        I replaced it and the SSD are fine. No more shorts.
        But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
        But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
        Chip marking...
        08-07-2025, 10:17 PM
      • SSBDADC234
        MacBook Pro 14". The screen DP chip failed.
        by SSBDADC234
        When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
        However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
        Testing the chip pins with a multimeter revealed a short circuit inside the chip.
        Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
        04-19-2024, 08:51 PM
      • Stephen
        A1989 Logic Board Repair Issue. One CD3215 chip is the culprit
        by Stephen
        As the title states, got one CD3215 chip being a complete butthole to me. All readings on the other 3 chips read as follows
        5.16V .47amp
        5.16V .47amp
        5.16V .47amp
        5.16V .04amp (this guy is the issue) (U3200)
        So I went ahead and replaced the chip, (actually 3 times with 3 new CD3215 chips) all same issue, at first it wasn't reading at all then it finally started reading. I can rest assured is it not the CD3215 chip now but something else is causing this port to not fully read (god I wish the board would just turn on so we can just recover the data)
        11-27-2023, 03:57 PM
