820-00138-A - Advice on how to fix corroded missing / pads
  • mikay786
    • Aug 2014
    • 765
    Working on this a MacBook i purchased, has some corrosion around what according to the schematic is SSD CURRENT SENSE circuit. I've got 3 missing pads
    The pad left side of R3742, where would be best to run a jumper wire too?
    I assume the other 2 missing pads should be simple enough with top C3701 pad which appears to be connected to the other components on the same plane. Pad on right side of R3742 just need to make sure is connected to trace.
    Mainly struggling with left pad of R3742 and where to run a jumper, maybe a via as appears to go to multiple places. Am i correct in thinking can run a jumper to any of the yellow points?
    Schematic and boardview in attached along with photos of board, plus spares board.
    [MOD EDIT] If the schematic is posted here at badcaps post a link to it,don`t attach it to this thread please.
    Reminder: rules and organization of this section
    https://www.badcaps.net/forum/troubl...f-this-section
  • reformatt
    • Feb 2020
    • 1468
    I assume you are referring to P3V3SSD_VMON from R3742? I'd just scrape off the mask on the track, and run a small wire to that, but you can also use the test point that's just above U3740 if that's too fiddly. How you do it is up to you, but I often put my component down first with the pad that is there, use conformal coating on the soldered end, then solder my jumper at the opposing end.
    • mikay786
      • Aug 2014
      • 765
      Managed to do it and is detecting ssd now.
      i left out R3742 as didn't seem to be doing anything? Just ran a jumper from broken trace straight to R3741.
      R3742 just seems like it’s connected to ground?
      I don’t want to keep fucking with it as those components are microscopic. So if I can do without R3742 would be ideal but not sure if needed?
      • mikay786
        • Aug 2014
        • 765
        Basically done this, see attached
        is that ok?
        • reformatt
          • Feb 2020
          • 1468
          It's part of a voltage monitor for the SSD 3.3V rail, nominal voltage is 1V to one input of the comparator in U3740. If the divider voltage is below 0.7V (due to PP3V3_S0SW_SSD being below 2.4V or so), the comparator output will stay low and hold the SSD in reset. Designers have put it there to force SSD to stay in reset if the SSD power rail is way below spec (assuming to prevent SSD data corruption). So under normal circumstances, it doesn't play a part. Leaving it out means that the input is tied to the rail, basically disabling that circuit.
          • mikay786
            • Aug 2014
            • 765
            Am I safe to leave as is or should I go back and add it?
            guess I could add it further down the trace so not having to risk the work already done.
            • reformatt
              • Feb 2020
              • 1468
              It's not really a circuit that is used if the 3.3V for the SSD is normal, so it's not an issue to leave it out. However, if you do want to add it for the sake of completeness, then just add the resistor to the test pad for P3V3SSD_VMON, and run a jumper to ground for the floating end if you don't want to mess with what you have done.
              • piernov
                • Jan 2016
                • 4437
                • France
                This is voltage/reset supervisor for power-on reset. I don't know if it's critical here, but even under normal circumstances it is useful as it waits for the power rail to be above a threshold + a constant delay before de-activating reset. This is done so that the SSD does not try to initialize before the power rail is stable after turning on the machine or waking up from sleep. It always take some time for a power rail to be fully stable at its nominal voltage. In some cases this kind of circuit is also used for proper power sequencing (to wait for other signals or power rails to come up).
                Personally I'd fix it properly, I never like to leave out random components.
                • ugamazing
                  820-02020 PPBUS_AON missing
                  by ugamazing
                  Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                  Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                  02-05-2025, 04:21 PM
                • jpreza
                  Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                  by jpreza
                  I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                  Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                  It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                  Looking at the card, it appears to be missing the following:
                  1x 1.0uH inductor - orange square
                  2x...
                  11-01-2024, 10:54 PM
                • gurj1979
                  Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                  by gurj1979
                  Hey guys.
                  Need help with this one.
                  Fan not spinning due to missing PWN Fan signal.
                  Also 5 seconds from powering up it freezes, unless in BIOS.
                  But as soon as Windows starts to load, it will freeze.
                  CPU is COLD / Room temp when it freezes.
                  I've replaced the CPU, same problem.
                  Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                  Replaced fan - same problem.
                  Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                  Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                  08-19-2024, 05:22 PM
                • salopian
                  Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                  by salopian
                  Hello. I would need some advice please.
                  My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                  He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                  I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                  I have already replaced the logic board with another...
                  02-27-2021, 07:30 AM
                • reessi
                  HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
                  by reessi
                  I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
                  It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
                  What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
                  I have checked these lines in diode mode and they seam normal -> 600.
                  I have checked to see if they come on for even a fraction of a second...
                  07-15-2025, 09:14 AM
