HP Probook 640 G4 not detecting the dc adapter and will not charge the battery
  • giagi
    Giagi
    • Oct 2017
    • 10
    • canada
    I have a HP Probook 640 G4 laptop which does not detect the DC charger and therefore will not charge the battery. I checked the dc adapter on another working probook 640 and it functions adequately.
    I checked the voltages coming in on the motherboard connector from the DC adapter to the bad unit and measured one voltage to be 19vdc and the other the center pin to be about 0.8vdc. I tested the battery and it was found to be OK.
    I am not sure what the center pin voltage should be. I suspect the problem to be a component on the dc input line on the motherboard but I do not have any schematics and I am not sure where to look. Can someone please help, I would greatly appreciate it
    Thx
    Nick
  • mon2
    • Dec 2019
    • 14672
    What is the history of this non-working unit?
    Any liquid damage?
    is the other working unit examined the same model as the non-working laptop?
    if you remove the battery and attach only the power adapter, does the laptop power up and boot normally?
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      First check dcin imosfets for internal short.
      Regards
      • giagi
        Giagi
        • Oct 2017
        • 10
        • canada
        As far as I know no water damage. The unit boots normally with or without the battery. The other unit is the exact same model. The only difference is that the good working one detects the ac adapter and the bad one does not.
        I cannot check dcin because I do not have schematics. can anyone provide a link to schematics. thanks for responding
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          Hi you got dcin charger then it will go to first and second mosfet you do not need shematics for this provide hd pictures . But check those mosfet between S-G , D-G , S-D IN OHMS MODE BEST 200 OHMS OR IF YOUR AUTORANGE DMM.
          • giagi
            Giagi
            • Oct 2017
            • 10
            • canada
            Steveb I have attached a few photos of the motherboard for you to look at
            • Stevedb
              Stevedb
              • Feb 2018
              • 624
              • Belgium
              Check d60200 and D6035 and check u6035 looks like a burned pin what is written on the ic.
              Regards
              • giagi
                Giagi
                • Oct 2017
                • 10
                • canada
                thanks a bunch stevedb
                • techfreak9356
                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                  by techfreak9356
                  I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                  09-14-2023, 11:10 PM
                • razenxd
                  How can I charge that battery pack?
                  by razenxd
                  it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                  At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                  Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                  Now, I have noticed a few things.
                  The "dead" battery, while connected to charger and NOT Charging will...
                  12-05-2024, 06:11 AM
                • ruletero
                  Acer a515-43 low battery charge voltage
                  by ruletero
                  Hi
                  Acer A515-43
                  LA-H801P
                  Fail: Does not charge battery, has low voltaje on connector.
                  Laptop didn't want to turn on, only charge led blinked.
                  I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                  I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                  Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                  10-24-2022, 02:31 PM
                  HP ProBook 640 G5 Notebook 600 Specification for Upgrade or Repair
                  This specification for the HP ProBook 640 G5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 boardview and 640 G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 640...
                  09-06-2024, 09:37 AM
                  DELL XPS 9365 Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                  This specification for the DELL XPS 9365 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9365 boardview and 9365 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9365 Hybrid...
                  09-06-2024, 05:40 AM
