Toshiba A300D power problem
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hi, i got this toshiba a300d with no display, fan spin for 2-3 sec. I thought it was the NEC/TOKIN issue, but i see there is SMD 330 smd. i can check them but i dont thik this is the problem. Does anybody have schematic for this board? it is
    DABD3GMB6EO REV E
    ...the quieter you become the more you are able to hear...
  • dj_ricoh
    • 2073
    Re: Toshiba A300D power problem
    did you try a reflow?
    you know amd video card :P
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      just finish with the reflow, it worked. But i hate this kind of reapir, i can never be sure it will last a day, month or year. I think in this situations it is the best to put a new VGA card.
      • dj_ricoh
        • 2073
        yeee!
        use a cooper plate so you won`t see the notebook again
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          Trust me i will.
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            just update, customer watch movie on laptop and black screen
            • lezsimply
              The Wanderer
              • 646
              • Philippines
              Reball?
              • alihomee
                • Dec 2012
                • 1577
                • malaysia
                change gpu
                • zendalo
                  • Aug 2013
                  • 8
                  • Portugal
                  Holla there!
                  I have A300D 14E motherboard ( DABD3GMB6E0)...In that part was maybe a fuse or somethin else thats was completely fried, and the motherboard was without power or any indicator to show a life, I remove the fried component it and now is power on, tested with external monitor is working...but now I dont know is it a fuse or some another electronic component.. Need a little help
                  P:S: I saw pictures here from the same motherboard and I noted that is missing a cable that connect the down right side from the hole 43 to Hole 6( CN17 to CN5)
                  Hope 4 help..Thanks
                  • Djosla
                    • Dec 2012
                    • 246
                    • Montenegro
                    no no no it`s not fuse it`s capacitor...big one i see,most likely on backlight power line...don`t put fuse...
                    • zendalo
                      • Aug 2013
                      • 8
                      • Portugal
                      Ah yeah! Crnogorac be nice and explain me which capacitor I need to put there.. The fried component was with a white colour...!
                      Daj molim te budi malo precizniji Nemam pojma iz elektronike al mogu da sredim ako dobijem instrukcije.
                      Kind regards from Macedonian in Portugal
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4977
                        • New Zealand
                        I guess you will need the schematic to find out what the capacitor should be
                        Edit: Think I found the schematic, see attached.
                        Check Page 20, top right for C26. Schematic says 10u/25V_1206
                        -David VanHorn
                        • Djosla
                          • Dec 2012
                          • 246
                          • Montenegro
                          yes it is 10u/25V...i did not have schematics before...thanks to agent24
                          • zendalo
                            • Aug 2013
                            • 8
                            • Portugal
                            Many many thanks ! I ll upload photo when theToshiba will be ready...
                            Tnx Agent 24, hvala lijepo Dj osla
                            • theone111
                              by theone111
                              3. Problem: TV shuts down
                              07-22-2024, 10:36 AM
                            • Duranitron
                              Asus x512dk rev 2.1 power on problem
                              by Duranitron
                              When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                              Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                              11-26-2024, 10:22 PM
                            • EazyBone
                              LG OLED55C9PUA power problem
                              by EazyBone
                              Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                              Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                              I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                              The power supply to t con is different story.
                              This...
                              06-23-2023, 07:43 AM
                            • Dr.d
                              Help please..Lenovo ideapad 5 14itl05 power and charging problem
                              by Dr.d
                              I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                              Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                              04-05-2024, 11:48 AM
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
