HP DV5 - DAQT6AMB8F0 REV:F shutdown in loop
  • marcellodj
    • Nov 2010
    • 99
    Good morning, i have this box, turns on,
    no caps blinks; the machine boots, i see the cursor on the screen blinking for few seconds, then restarts, in loop for hours.already reflashed bios, changed cpu,ram.but same issue.
    the board don t have the nec supercrap, anyone faced with same issue?
    thanks for attention
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: HP DV5 - DAQT6AMB8F0 REV:F shutdown in loop
    if its ATI vga series HD4xxx or HD5xxx reflow it
    Im Back... sort of...
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      if i were to troubleshoot that, i would boot first using a windows live CD/Hiren or the likes.
      it looks like OS issue to me.
      hope this helps
      • Francisco.s
        • 686
        • Spain
        PC17,PC18 and PC146,PC150 do the job like nec-tokin in other motherboard.
        Does it work properly only with battery?
        • marcellodj
          • Nov 2010
          • 99
          repacked and sento back to customer without repairing.close topic
          • SuperJames
            Dell G3 17 3779 Weird power cycling and shutdown/restart issue
            by SuperJames
            This one's a weird one, and still unsolved despite it having gone back to Dell once.
            Specs
            i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
            Backstory
            I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
            10-23-2023, 04:09 PM
          • kalilinux25
            Power Issue, if shutdown it wont power on again.FH5AT LA-K092P REV 2.0
            by kalilinux25
            Hi good day I have a issue of this motherboard laptop, if doing a cmos reset the the motherboard ( discharge the current inside the board) it will power on and if you shutdown
            the laptop it wont power , it will shows led light for a second then shutdown.
            Tried clean Me bios smae issue
            tried to bypass thermal protection ( remove RB7 and RB1 and jumper each pad of the DB1 )
            ive check the motherboard for corrion but no avail
            Hope someone can guide which part of the board should I focus to narrow down the issue
            FH5AT LA-K092P REV 2...
            10-06-2023, 12:49 AM
          • javierwilliam
            Boot loop issue with LCD TV
            by javierwilliam
            I am experiencing boot loop issues with my LCD TV. When the TV briefly displays the logo, such as LG or Philips, and then shuts down only to repeat this cycle, it indicates a boot loop problem. The challenge lies in the inability to install new software under these circumstances.
            Should I consider replacing the mainboard as a solution, or are there alternative approaches to address this issue?
            Thanks in advance!​
            08-29-2024, 04:06 AM
          • abajor
            Alienware Area-51 R2 Boot Loop issue.
            by abajor
            I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
            It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
            To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
            Right now I'm trying to dig through the PDF schematics and Board...
            03-08-2024, 10:08 PM
          • luis71
            PANASONIC TX-43HX580E VESTEL 17mb230 Boot Loop issue
            by luis71
            Hello,i have panasonic TX-43HX580E,I tried to enable 48 bit color,HDR10+ and ALLM and stuck at boot loop screen.I have modified edid.edid.
            I have backed up PQ,SPI,and Profile if anyone want
            Which usb_auto_update_??.txt can i use to dump firmware?
            I would be grateful if anyone could help me to find the firmware for USB recovery.
            11-05-2023, 06:31 AM
