Power Issue, if shutdown it wont power on again.FH5AT LA-K092P REV 2.0
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi good day I have a issue of this motherboard laptop, if doing a cmos reset the the motherboard ( discharge the current inside the board) it will power on and if you shutdown
    the laptop it wont power , it will shows led light for a second then shutdown.
    Tried clean Me bios smae issue
    tried to bypass thermal protection ( remove RB7 and RB1 and jumper each pad of the DB1 )
    ive check the motherboard for corrion but no avail
    Hope someone can guide which part of the board should I focus to narrow down the issue
    Last edited by SMDFlea; 10-06-2023, 01:48 AM. Reason: Added "FH5AT LA-K092P REV 2.0" to thread title..
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Power Issue, if shutdown it wont power on again.FH5AT LA-K092P REV 2.0
    This is not related to thermal protection as mb is posting after cmos reset. I'll suggest to look for RTC circuit deeply.
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      Thanks i just returned it because the person was so hurry and need it back, but I made a baypass so he can use it, press the reset buitton at the back for 20s then plug the charger and power on, but may i ask why those it get damage the RTC section?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Really cant explain the "N" number of reasons for RTC circuit malfunction. This however remains one of the most prominent problem in laptop boards. Some times can be fixed,in some cases its PCH's RTC section itself gets shorted-completly/partially.
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • SuperJames
          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
          by SuperJames
          This one's a weird one, and still unsolved despite it having gone back to Dell once.
          Specs
          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
          Backstory
          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
          10-23-2023, 04:09 PM
        • justice171
          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
          by justice171
          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
          1. Verified that all critical voltages are present:
            • 3.3V and 5V are always present if DC is plugged.
            • 1.8V on the BIOS chip is present.
          2. Checked the power button functionality:
            • When pressed, the voltage drops to 0V, indicating the button is functional.
          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
            • Confirmed connectivity is intact, ruling out issues
          11-26-2024, 12:39 AM
        • claws77
          lenovo flex 5 14itl05 power sequence issue
          by claws77
          hi guys, my motherboard will not start no matter what
          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
          but rest nothing happens no sign of life.
          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
          i have no knowledge of motherboards ....
          10-20-2024, 02:48 PM
        • Soulzink
          Samsug washing machine. Power supply DC41-00189a board issue
          by Soulzink
          I am trying to fix a samsung washinmachine power supply main board.
          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
          The power supply board reference is the following: DC41-00189a
          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
          04-19-2025, 06:26 AM
