HP Compac NX9420- Not Open
  • olorin
    • Sep 2013
    • 82
    • Greece
    Hi friends.
    I have one HP Compac NX9420. Τhe problem is that the laptop not work at all with either battery or with AC power supply.
    Once I press the power button one indicator light, mark that has the thunder, flashes red 8 times.
    I removed the graphic card but the problem continues....
    What could be wrong?
    Thank's!
  • spleenharvester
    • Mar 2010
    • 921
    Re: HP Compac NX9420- Not Open
    I had something similar happen after I shorted the 5V source to ground by accident on an NX6110. Clear the CMOS, remove all sources of power (inc CMOS battery) then try again. Worked for me.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • olorin
      • Sep 2013
      • 82
      • Greece
      Sorry for the delay....
      I removed CMOS Battery and I gave up without power for a day...
      I tried then with its own power supply, but also with other, but again doing the same problem.
      • dj_ricoh
        • 2073
        • uk
        Usually that means you don't have enough power.
        Try a differit ac adapter, more powerful and find another battery.
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          " flashes red 8 times." why dont you check this error code from manufacturer web site?
          • olorin
            • Sep 2013
            • 82
            • Greece
            I have ticked with more powerful power supply and without battery.
            • olorin
              • Sep 2013
              • 82
              • Greece
              On some computers, the motherboard can flash or change the color of lights on the outside of the case, such as the power button LED and the hard drive activity LED. For computers that support this technology, lights blink and and provide a beep to indicate a failure condition.
              LED and beep condition Description
              Power button LED blinks 4 times with 4 beeps Power Supply
              Power button LED blinks 5 times with 5 beeps Memory
              Power button LED blinks 6 times with 6 beeps Video Card or Graphics
              Power button LED blinks 7 times with 7 beeps Motherboard or System Board failure
              Power button LED blinks 8 times with 8 beeps BIOS or CMOS problem (ROM)
              ...the above says HP
              I do not know yet if it is a problem of the ROM. When inside the battery and connect the power supply the power led continuously flashing red.
              • bluestone
                • Jun 2011
                • 343
                • Ghana
                Try recovering the bios first.
                • olorin
                  • Sep 2013
                  • 82
                  • Greece
                  Thank you.!But how to do this?
                  • olorin
                    • Sep 2013
                    • 82
                    • Greece
                    I found a burnt LM393 on motherboard.
                    So this would be the problem.But I want to check and the neighboring components lest be burned.So I should like the schematic diagram of motherboard -EAL 80 LA-2821P- to see what other components are on the LM393.
                    • spleenharvester
                      • Mar 2010
                      • 921
                      http://www.mmnt.net/db/0/15/80.70.23...ebook1/Compal/
                      Seems to be in there. But I haven't downloaded it so no idea if it is the right one.
                      • olorin
                        • Sep 2013
                        • 82
                        • Greece
                        The LM393 can be replaced by AZV393 ( ) ?
                        • olorin
                          • Sep 2013
                          • 82
                          • Greece
                          I replaced LM393 and one MOSFET that I found even burnt.Now the laptop it works swimmingly!!!
