not charging but showing few seconds charging display when i connect adapter i have changed new adapter 95w and 130w still same condition please give me any solution?
Dell 5010
Tags: None
Re: Dell 5010
This is kinda rude .
Did you at least took out the motherboard out, made some basic checking visual for some burned components, maybe overheating.
With a dmm you can check some MOSFETs near the power jack .
Basic stuff you need to do first .
You just ask for solution .do you think that whe know what's inside your notebook until you open it.
Open so we can know what's inside and TRY to help.
Good luck and a good day to you sirJust cook it! It's already broken. -
Re: Dell 5010
I think most dell laptops have got this same issue and it is always the Adapter, If you put on the laptop you get a message like "Alert' Ac adapter cannot be determine" then your laptop can't charge, you should try and find the correct adapter for your laptop.Comment
by vickey_vipHi I need bios for dell OptiPlex 3050 all in one mb part is ipkbl-sr/35w.
Old bios display is coming but giving following error
(A7) FW downgrade - request mespilock fail upon starting
After this error all in one again restart and again same error not booting
I am attaching here old file
Urgent help required because its server pc of someone
Link of dell page here
https://www.dell.com/support/home/en...SQT090/drivers...-
by jake-bgood morning all,
i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other... -
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... -
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
- Loading...
