Dell 5010
  • laptopservice
    • Oct 2013
    • 35
    • india
    Dell 5010
    not charging but showing few seconds charging display when i connect adapter i have changed new adapter 95w and 130w still same condition please give me any solution?
  • dj_ricoh
    • 2073
    • uk
    Re: Dell 5010
    This is kinda rude .
    Did you at least took out the motherboard out, made some basic checking visual for some burned components, maybe overheating.
    With a dmm you can check some MOSFETs near the power jack .
    Basic stuff you need to do first .
    You just ask for solution .do you think that whe know what's inside your notebook until you open it.
    Open so we can know what's inside and TRY to help.
    Good luck and a good day to you sir
    • lord
      • May 2011
      • 319
      • Croatia
      Re: Dell 5010
      And also make sure you have a good opearting battery.
      Nice one. In gloves
      • bluestone
        • Jun 2011
        • 343
        • Ghana
        Re: Dell 5010
        I think most dell laptops have got this same issue and it is always the Adapter, If you put on the laptop you get a message like "Alert' Ac adapter cannot be determine" then your laptop can't charge, you should try and find the correct adapter for your laptop.
        • vickey_vip
          dell OptiPlex 3050 all in one bios error solution
          by vickey_vip
          Hi I need bios for dell OptiPlex 3050 all in one mb part is ipkbl-sr/35w.
          Old bios display is coming but giving following error
          (A7) FW downgrade - request mespilock fail upon starting
          After this error all in one again restart and again same error not booting
          I am attaching here old file
          Urgent help required because its server pc of someone
          Link of dell page here
          https://www.dell.com/support/home/en...SQT090/drivers...
          02-23-2024, 11:49 PM
        • jake-b
          dell e6540 boots to black screen (no dell logo)
          by jake-b
          good morning all,
          i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
          01-08-2024, 10:29 AM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
        • diamon
          Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
          by diamon
          I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
          Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
          Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
          Pictures of these boards:
          Dell Latitude 5520 https://www.ebay.com/itm/256052956663
          Dell Latitude 5530 https://www.ebay.com/itm/125844181534
          Dell...
          02-28-2024, 12:51 PM
        • OntarioTL
          Dell 5410 greyed out BT
          by OntarioTL
          Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
          If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
          Dell Lattitude 5410
          Service Tag...
          Today, 01:28 PM
