E system 1201 FN key driver?
  • artois7
    • Mar 2011
    • 159
    Getting ready to throw this one out the window! E system 1201 model, came to me without a harddrive. Got Vista installed and all drivers, everything is working apart from the wireless. It's one of the models where you have to press fn + F10 before the wireless is enabled, but this doesn't seem to activate it on a clean install.
    I assume a driver is missing which controls the FN key? I thought it would be part of the chipset driver but that installed fine. I've tried changing the wifi card just on the off chance, but no luck.
    Any ideas how I can get this enabled? Can't even find a BIOS update for it.
  • dj_ricoh
    • 2073
    • uk
    Re: E system 1201 FN key driver?
    'I've tried changing the wifi card just on the off chance, but no luck.'
    What?
    Did you change the WiFi card?
    Many got in BIOS fn multifunction key so you need to disable it
    • artois7
      • Mar 2011
      • 159
      I did change the wifi card, to a 3945 intel card. Didn't make any difference. The bios is very limited with no such options, any idea where I can get a bios update? Can't find one.
      • tomodachi
        • Apr 2012
        • 612
        • Turkey
        Does windows recognize wifi card ? I mean can you see it on device manager menu ?
        • artois7
          • Mar 2011
          • 159
          Nope, nothing. I assume the card is only activated when fn + f10 is activated.
          • tomodachi
            • Apr 2012
            • 612
            • Turkey
            Evenif you press buttons or not wifi card must be hanging on device manager. if not then your problem is not related to Fn + F buttons, you should check PCI slot first, maybe an incompatible wifi card ? once the wifi appeared on your device manager list you will not need any driver or Fn+ F combination to enable wireless function I assume.
            • domas
              News Hater
              • May 2013
              • 323
              • Denmark
              no, it actually does not all the time, at least not on my dell laptop, just tested it a sec ago, my combination is Fn+F2 and bluetooth disappeared from device manager. Wifi card did stay though.
              is it then driver-dependant?
              • tomodachi
                • Apr 2012
                • 612
                • Turkey
                Then yours is a driver case.
                • cyberhack
                  • Feb 2013
                  • 466
                  • Uk
                  http://www.emachines.com/ec/en/US/content/home
                  • domas
                    News Hater
                    • May 2013
                    • 323
                    • Denmark
                    you need this app
                    http://global-download.gateway.com/G...HINES&SC=PA_6E
                    • Francisco.s
                      • 686
                      • Spain
                      What's this app. for? could you explain?
                      Thanks.
                      • domas
                        News Hater
                        • May 2013
                        • 323
                        • Denmark
                        for enabling proper operation of Fn + Fxxx button combinations
                        • artois7
                          • Mar 2011
                          • 159
                          Unfortunately it won't install as it's for 7 and I'm on a Vista system. Tried another from that website for Vista but it's disabled my mouse. Is there anything in particular about that version / link that applies to my laptop?
                          Thanks.
                          • spidey
                            climbs
                            • Dec 2012
                            • 644
                            • Cyprus
                            you must find manufacturer web site and download power managment drivers.
                            • artois7
                              • Mar 2011
                              • 159
                              E system no longer offer any support for any of their products I'm afraid mate.
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                well, unless you can get the drivers second hand i guess it may have just became a part of the MFG abandoned department.....
                                Follow the white rabbit.
                                • Learn2Day
                                  • Jun 2013
                                  • 254
                                  • Portugal
                                  Why not just install Win7 and problem solved?...
                                  On a side note, many e-machines and Packard Bell laptops are acer re-brands (not sure it applies to e-system), but might be worth finding the compatible acer model and test hotkey SW from acer..
                                  Galaxy S6 Edge x2 (Gold&White)
                                  Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
                                  Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
                                  Try Harder!
                                  • artois7
                                    • Mar 2011
                                    • 159
                                    Solution:
                                    Thanks to those who contributed. In the end it was nothing to do with the FN key driver; I ended up reinstalling the original wireless card ( I upgraded it to an Intel device originally, which wasn't even picked up by the system) then managed to find drivers for the RTL8187b which works.
                                      MSI Workstation WF65 10TH-1201 Mobile workstation WF65 Specification for Upgrade or Repair
                                      This specification for the MSI Workstation WF65 10TH-1201 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the WF65 10TH-1201 boardview and WF65 10TH-1201 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 07:50 PM
                                    • osrex
                                      LED DRIVER KEEPS DYING
                                      by osrex
                                      Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                      i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                      i have no datasheet at all for the LED lights, all i have is its length.
                                      long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                      as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                      05-05-2025, 03:36 PM
                                      HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Backpack & Wireless Premium Mouse boardview and 430 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                      09-06-2024, 03:30 PM
                                      HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + Backpack & Wireless Premium Mouse boardview and 640 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                      HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
