G61-405el
  • mazloum
    • Sep 2012
    • 503
    • Lebanon
    G61-405el
    hello
    i had this hp with the following problem:
    at first when I plug the ac adapter , the led of the input power will be on for 2-3 sec then goes off, i press the power button but no activity, i took the parts of the laptop apart , also changed bios with no power still, i reinsert the old bios tried again , the laptop works good but with no information "pn, sn etc...." on the bios. i used nbdmifit and entered evey thing and made a bios update from f21 to f23 th latest one and boot it again, it booted up but with no sound card at all....
    but the worst thing is when i shutdown the laptop and try to boot again it will hang , so sometimes boots up but most of cases it will not and hang up....i tried new ram hdd with no succes.... i forgot to mention tha ram will be very hot even when i change it. but when i enter dos it will work forever with no hang
    thanks in advance
  • tomodachi
    • Apr 2012
    • 610
    • Turkey
    Re: G61-405el
    Overheating of ram is normal, that s why all notebook's ram covers has holes or ram cooling air circulation design inside.
    About hang on, were u tested it with or without HDD ? it seemed like a bad sector to me.
    • mazloum
      • Sep 2012
      • 503
      • Lebanon
      Re: G61-405el
      i put another hdd, but the same error
      • kenkaniff
        HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
        by kenkaniff
        Product Name: HP Pro x360 Fortis 11-inch G9
        System BIOS: U94 Ver.01.08.00 10/06/2023
        Serial Number: 5CG31946F5
        SKU Number: 85W05EC#AK8
        Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
        This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
        I needed to remove bios password...
        10-01-2025, 04:32 AM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • q2v5
        Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
        by q2v5
        Lenovo T480s
        Model 20L8-S3TE00
        Board ET481-U10
        Chip MX25L12873F
        Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
        2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
        The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
        08-15-2024, 10:40 PM
      • Max029
        Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
        by Max029
        I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
        I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
        TY,
        08-18-2024, 08:28 PM
      • 0xx
        2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
        by 0xx
        Hi folks,
        My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
        What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
        I assumed that Windows Update was interrupted due to closing...
        09-14-2025, 03:46 PM
