G61-405el
  • mazloum
    • Sep 2012
    • 499
    • Lebanon
    G61-405el
    hello
    i had this hp with the following problem:
    at first when I plug the ac adapter , the led of the input power will be on for 2-3 sec then goes off, i press the power button but no activity, i took the parts of the laptop apart , also changed bios with no power still, i reinsert the old bios tried again , the laptop works good but with no information "pn, sn etc...." on the bios. i used nbdmifit and entered evey thing and made a bios update from f21 to f23 th latest one and boot it again, it booted up but with no sound card at all....
    but the worst thing is when i shutdown the laptop and try to boot again it will hang , so sometimes boots up but most of cases it will not and hang up....i tried new ram hdd with no succes.... i forgot to mention tha ram will be very hot even when i change it. but when i enter dos it will work forever with no hang
    thanks in advance
  • tomodachi
    • Apr 2012
    • 603
    • Turkey
    Re: G61-405el
    Overheating of ram is normal, that s why all notebook's ram covers has holes or ram cooling air circulation design inside.
    About hang on, were u tested it with or without HDD ? it seemed like a bad sector to me.
    • mazloum
      • Sep 2012
      • 499
      • Lebanon
      Re: G61-405el
      i put another hdd, but the same error
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • q2v5
        Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
        by q2v5
        Lenovo T480s
        Model 20L8-S3TE00
        Board ET481-U10
        Chip MX25L12873F
        Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
        2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
        The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
        08-15-2024, 10:40 PM
      • Max029
        Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
        by Max029
        I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
        I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
        TY,
        08-18-2024, 08:28 PM
      • futadmytro
        Asus g713qm-es94 stuck on boot bios problem
        by futadmytro
        sn^M4NRKD02753616E
        MB- g533-6050a3250201-MB-A03
        Stuck on boot after ROG logo, did not enter to bios
        In flash bios , laprop boot but have video issue
        orig bios...
        06-25-2025, 08:07 AM
        by Vesko356
        08-11-2023, 03:27 AM
