ASUS K51AC Problem
  • olorin
    • Sep 2013
    • 82
    • Greece
    ASUS K51AC Problem
    Hello guys!
    I have one ASUS K51AC makes a strange problem.
    Suddenly he could not get into Windows 7.Ηang on boot screen..But it can sometimes get normal!
    I changed the hard disk and Ram.I pulled out all of the unnecessary(CDROM,wi-fi card e.t.c.).I did a new installation of Windows but still do not enter!
    I tried with ubuntu, works fine but can not reboot.I tried with Mini XP of Hirens Boot , works fine but can not reboot again.
    Τhe BIOS is the latest version!
    What could be the problem?
    Thank you!
  • olorin
    • Sep 2013
    • 82
    • Greece
    Re: ASUS K51AC Problem
    Any help guys??
    • jtamad44
      • Apr 2013
      • 145
      • israel
      could be the SB chip, happend to my asus before, reflow it works fine, but after 2 months, went back again, so i decided to change the chip, now works like a charm..
      • olorin
        • Sep 2013
        • 82
        • Greece
        Thanks for the reply..!!
        And I misdoubt the Southbridge chipset but I'm not sure.
        In your own case jtamad44 your presents similar problems to mine?
        If I make a reflow at southbridge chipset there is danger of missing completely?
        Thank you again!
        • olorin
          • Sep 2013
          • 82
          • Greece
          • whaldsz
            • Apr 2013
            • 395
            • Philippines
            possibly overheating problem? Why don't you run a diagnostic software and monitor the temperature? It might give a clue as to what caused its abnormal behavior.
            • olorin
              • Sep 2013
              • 82
              • Greece
              The temperatures are normal!I clean very well the cooling system!There is not the problem there!
              The laptop works great when opened!
              • olorin
                • Sep 2013
                • 82
                • Greece
                With ubuntu works flawlessly!
                Having trouble with Windows!!!
                • dj_ricoh
                  • 2073
                  • uk
                  you got a ati chip and if you don`t install the proper driver it will overheat.
                  95% got this problem; try thermal sponge on memory and chipset then try thermal compound with cooper plates
                  • olorin
                    • Sep 2013
                    • 82
                    • Greece
                    Thanks for your answer. I have installed GPU driver.I have tried with Windows 7 and Windows 8.They have the same problem.
                    I do not think is a matter of overheating, because in the ubuntu everything works flawlessly.Plays 1080p video on youtube without any problem.
                    Also in Windows ,thereby opening, they could not being restarted.The problem is hidden somewhere else
                    • Francisco.s
                      • 686
                      • Spain
                      Have you tried a windows-based live-cd, like hirens´s?
                      If not, try it, and run Everest or Aida-64 and run stability test.
                      Post results.
                      • olorin
                        • Sep 2013
                        • 82
                        • Greece
                        Post results.
                        I have try Mini XP from hiren's Boot cd works fine but does not restart.
                        I ran Burnin software when they worked the Windows for 10 hours and not found any problems
                        • olorin
                          • Sep 2013
                          • 82
                          • Greece
                          Now I entered with mini XP of Hirens Boot.Just tell him to restart or termination, hangs!!!
                          • alihomee
                            • Dec 2012
                            • 1574
                            • malaysia
                            95% sb chipest fault
                            • olorin
                              • Sep 2013
                              • 82
                              • Greece
                              But why Southbridge?
                              Ubuntu are working!
                              • dj_ricoh
                                • 2073
                                • uk
                                DUDE!! how many drivers did you install? how many times you install(clean) windows.
                                you need to install windows for clean drivers and you need gpu sensor sft so you can see.
                                if ubuntu runs fine then its driver problem
                                • Francisco.s
                                  • 686
                                  • Spain
                                  A few months ago, I faced a similar problem with an ASUS X59.
                                  Booted well with Hiren´s, (not in Ubuntu) and run Everest without any problem, but hanged on every shut down. ( restart OK)
                                  Couldn't install xp or w-7, but w-2k3 was installed perfectly with default drivers.
                                  Probably the problem was in south-bridge, but didn't accepted to repair it and I can't say for sure where the problem was.
                                  • olorin
                                    • Sep 2013
                                    • 82
                                    • Greece
                                    But I had installed the last drivers!!!!
                                    He did exactly the same!
                                    • olorin
                                      • Sep 2013
                                      • 82
                                      • Greece
                                      Οκ Francisco....I will not continue ....I will leave with ubuntu
                                      Many many thanks for your help!!
                                      • AtelierRepa
                                        ASUS X712JA problem
                                        by AtelierRepa
                                        I have a problem with the bios, let me explain.
                                        With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                                        I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                                        My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                                        The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                                        06-15-2024, 04:33 AM
                                      • rounin
                                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                        by rounin
                                        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                        🛠 Original Issue
                                        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                        04-19-2025, 01:18 AM
                                      • Dobrowol
                                        Asus GA402RK keyboard and kb backlight problem
                                        by Dobrowol
                                        Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                        04-28-2025, 04:30 PM
                                        ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                        This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                        09-07-2024, 02:50 AM
                                        ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
