Dell XPS M1710: GPU Fan Not Working
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Yet another laptop Im working on, as in title.
    Laptop gets very hot but only CPU fan comes on. Any ideas? Can I just bridge the CPU Fan's connection to the GPU Fan's connection? That would save some time. Need to collect payment fast
    The first issue was no graphics so I reballed the GPU and all is well. But now I see a fan not working. Fan was not working before the reballing.
    Thanks.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • dj_ricoh
    • 2073
    Re: Dell XPS M1710: GPU Fan Not Working
    hello!
    i have a xps m1710 at home colecting dust and dell m6300 ( a friends notebook)
    xps--> power on no display if a press FN+power it shows a CPU ERROR code (it will colect dust )
    that M6300 was over heating and we cleaned after assembelingthe 2 fan stop working; for the video fan there is a powerd mosfet that you can skip by bridging it and it will run as normal because the yellow wire can provide power so the fan can work faster if video hot, but the cpu fan you need to take 5v from near power bord usb( just cut the red wire and put it on direct on usb board.
    The strange problem is that the yellow wire from CPU give voltage normal (for RPM) but there is not 5v on red wire, my guess is ic controler is half faulty;
    One direct one normal ( i done this job in 30 min cuz my friend was making money with that m6300)
    i wish you good luck and i know you can do it
    • speedypro
      • Feb 2013
      • 561
      • United Kingdom
      Originally posted by dj_ricoh
      hello!
      Bridging it is
      • speedypro
        • Feb 2013
        • 561
        • United Kingdom
        Bridged and both fans are now running. Case SOLVED!
        • Dukenukemx
          • Nov 2012
          • 43
          Got a similar problem as speedypro, but both fans don't power on. I tested the fans with a 9v battery and they power on. The first issue for me was no graphics, but I used a heat gun to reflow. Now I find the fans won't go on.
          Any idea where the fan controller is on this laptop?
          • Dukenukemx
            • Nov 2012
            • 43
            I got the fans to work by using a heat gun on the north bridge and the south bridge chips on the board. It also turns out the Dell bios likes to turn on the fans when the chips are melting apparently. Would explain the weak solder joints on everything. So I use i8kfanGUI to keep everything cool. I hope you like disabling digitally signed drivers btw.
            When I say Dell, I mean Clevo, as in this thing is clearly made by Clevo.
            • atsio
              • Oct 2013
              • 819
              • Greece
              Actually it is a Compal Board. Probably the problem is a problematic thermal sensor. I have read in other forum posts that a lot of people reset the thermal sensors on Dell laptops by pressing the Fn+Z keys.
              • emil_t
                RTX3090 working fine but fans not spinning
                by emil_t
                Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                04-12-2024, 06:54 AM
              • MMH3
                Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                by MMH3
                i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                Never ever i experienced problems with that.
                Now i have one 5050sff machine, where this jumper isnt working at all.
                I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                The history of the machine is that i used it in my office...
                03-23-2025, 09:28 PM
              • jayakumar
                dell 5490 la-f401p no display ( in HDMI out working )
                by jayakumar
                I have dell 5490 la-f401p problem: no display ( in HDMI out working )
                changed working bios ,working screen ,cable
                Please help me to resolve the issue
                i have more then 7 laptop's having the issue
                08-06-2024, 10:03 PM
              • Mirenia
                Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                by Mirenia
                I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                03-30-2025, 06:47 AM
              • eliemgh
                Dell Latitude 7410. The USB Type-C port is not working
                by eliemgh
                I have a Dell Latitude 7410 with an Intel i7 10th Gen CPU. The USB Type-C port is not working, and since it's the only charging port on the device, I'm unable to charge the laptop.
                I inspected the motherboard and found that the IC labeled TPS65988 had a short circuit. I ordered a replacement IC from Alibaba and replaced it. The short issue is now resolved, but the laptop still doesn't charge, and the Type-C port remains non-functional.
                After doing some research, I found out that the TPS65988 needs to be programmed after replacement in order to function properly.
                04-14-2025, 04:20 AM
