Toshiba Sat M300.. Error Resource Conflict?
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Good Day To All.
    I Have Toshiba Satellite M300.
    If I Turn On. Then P.O.S.T have Message Display
    ERROR
    Resource Conflict - PCI Serial Bus Controller On MotherBoard
    Bus:0A, Device:01, Function:00
    ERROR
    Resource Conflict - PCI On MotherBoard
    Bus:0A, Device:01, Function:02
    ERROR
    Resource Conflict - PCI Mass Storage Controller On MotherBoard
    Bus:0A, Device:01, Function:03
    I Try To CLean 1st. nothing happen Same as Problem
    I Remove HDD - DVDrom - MODEM also I change The Memory. Nothing Happen
    Can You Help me.....
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Re: Toshiba Sat M300.. Error Resource Conflict?
    Follow Up....
    Also i remove the Wifi Card... Same As
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      i would update the bios first, and load defaults. Then if it doesnt solve the problem reflow southbridge.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        did you clear cmos?
        • RJARRRPCGP
          • Jul 2004
          • 6304
          That don't even make sense with a post-1994 PC! It should have assigned different addresses on its own. (Unless it's a desktop unit with a PCI disk interface card inserted without disabling the onboard disk controller.)
          Conflicts were what folks with PCs in the ISA slot era commonly had.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • lorins_core
            BlackSmith
            • Dec 2012
            • 552
            • Philippines
            Originally posted by kc8adu
            did you clear cmos?
            i already do that nothing happen
            • lorins_core
              BlackSmith
              • Dec 2012
              • 552
              • Philippines
              so you thing have No Solution on this Problem? Peace Men
              • lorins_core
                BlackSmith
                • Dec 2012
                • 552
                • Philippines
                Yes Sir Spidey.... I Think You Have A Point. But how Come? how can Update the Bios Can't Load The USB. Can you Teach me How? well Pls.
                • alihomee
                  • Dec 2012
                  • 1591
                  • malaysia
                  you need to flash the bios chip with a device......first take it out from motherboard
                  • spidey
                    climbs
                    • Dec 2012
                    • 644
                    • Cyprus
                    delsolder chip and flash it with a programmer.
                    • lorins_core
                      BlackSmith
                      • Dec 2012
                      • 552
                      • Philippines
                      You Mean I remove The Bios In Mobo(MotherBoard). Then How to Flash The ROM BIOS? Where I Flash It? In Other MOBO?
                      • whaldsz
                        • Apr 2013
                        • 395
                        • Philippines
                        you remove the BIOS chip from the board and use a bios programmer (see this link for example - Willem Programmer) to flash bios file that is compatible with your mobo.
                        • lorins_core
                          BlackSmith
                          • Dec 2012
                          • 552
                          • Philippines
                          Salamat Tropa....
                          TY.... To All Now i Know.
                          • jean luc ferre
                            upgrading windows7 to windows10 on an old laptop toshiba satellite m40 331 allways in error
                            by jean luc ferre
                            on this old laptop toshiba satellite m40 331 i am trying (but failing) to upgrade frow w7 to w10 and allways i have the error : 0xc1900101 - 0c20017. The upgrading process stops with the pc blocked with the logo screen w10 on the display; then there is no activity on the disk hdd or ssd.
                            it's also impossible to boot from a dvd iso bootable, the device equally blocks on the w10 logo screen...
                            i verified the informations in the device manager and it seems there are no problems...
                            i wonder if it's not an issue about the bios (which is very old) or an interface problem...
                            05-27-2025, 07:13 AM
                          • Sus256
                            HISENSE 65E7KQ PRO - no boot
                            by Sus256
                            Hi all!
                            HISENSE 65E7KQ PRO
                            RSAG7.820.13512 - chassis
                            MT9618BAATAB - cpu
                            RSAG7.820.12059 - power
                            HD650Y3U77 - panel
                            KLM8G1GETF - emmc
                            The TV does not turn on, the standby indicator is on. All voltages are present.
                            Emms is dead. Not readable, not detected.
                            Replaced emmc.
                            But with another dump there is no launch
                            Terminal log
                            UART
                            AC_ON
                            RPMB key is not yet programmed
                            HASH1_VERSION=0x00000000 64bit
                            E-B
                            FDE enabled
                            layout pattern onebin by SAR7,0...
                            06-01-2025, 02:11 AM
                          • sushilachuthan
                            APC UPS error P13
                            by sushilachuthan
                            one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                            the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                            The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                            We replaced the SCR with new device,, but the device is not power on as expected.
                            Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                            09-26-2025, 09:00 AM
                          • CornholioGSM
                            RT809H - direct read Toshiba eMMC timeout error
                            by CornholioGSM
                            Hello all,
                            help needed.
                            I want to made backup of boot and all partitions from emmc desoldered from old phone.
                            So i have wired emmc directly to RT809h - Dat0, GND,CMD, CLK, VCC, VCCQ - on programmer sw set Smart Identify to EMMC ISP and voltage to 3.3V.
                            In Settings (N) i have set area to user, boot1,boot2 and EXT and vccq set to 1.8V (tested 3.3V too).
                            Problem is, that i still get Read Timeout Error
                            OK - emmc can be dead...so i have tested emmc wires connection to micro SD adapter and then in card reader and emmc was detected.
                            So...
                            01-16-2025, 04:34 PM
                            Toshiba Satellite Pro M300 M305 Laptop Schematic
                            Toshiba Satellite Pro M300 M305 Laptop Schematic...
                            10-08-2024, 01:57 PM
