Repair Logic Board MBP 13'' A1278 - K24
  • jpdo
    • Jul 2013
    • 23
    • Portugal
    I have an macbook pro and only works with charged battery, no power or charge with a magsafe.
    I have read some voltages as you can see in the pictures attached.
    With the DC-IN adapter out of logic board i have the correct voltages but when i connect it i dont have the voltages correct and are unstable.
    What i need to verify to try solve this problem?
    Can anyone help-me please?
  • jpdo
    • Jul 2013
    • 23
    • Portugal
    Re: Repair Logic Board MBP 13'' A1278 - K24
    Anyone can tell-me what is this component (in yellow circle) and what serves
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      Looks like a SMD resistor/diode/capacitor. Can you take a closer picture of it?
      I can put text here?!
      • jpdo
        • Jul 2013
        • 23
        • Portugal
        unfortunatly i cannot take a pictur more closer because my motherboard have this missung component.
        • DJduck
          • Dec 2012
          • 229
          • Estonia
          Since it is black, its a resistor or a diode. If you can get a schematic for this laptop, then you could maybe identify that.
          I found this: http://schemalaptop.blogspot.com/201...cbook-pro.html
          • DJduck
            • Dec 2012
            • 229
            • Estonia
            If any of the regulators/mosfets are causing problems (unstable voltages) you should replace them.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Tried a different charger?
              Muh-soggy-knee
              • jpdo
                • Jul 2013
                • 23
                • Portugal
                Yes i tried an different charger and doesnt work. Is the same thing.
                • jpdo
                  • Jul 2013
                  • 23
                  • Portugal
                  But i dont know for where start because when i measure the dc-in board when is connected to logic board the voltages are unstable (between 0 and 15v) but when isn't connected the voltages are ok (stable 6.25v) in dc-in board.
                  • robrock1
                    • Jul 2013
                    • 129
                    • Ghana
                    have you checked for any shorts? maybe something is getting hot?
                    • jpdo
                      • Jul 2013
                      • 23
                      • Portugal
                      My macbook now charges and turns on but with external monitor everything works fine, but with macbook display only appears white with some black stains, do you know what can be?.
                      • jtamad44
                        • Apr 2013
                        • 145
                        • israel
                        in that case, change screen panel
                        • jpdo
                          • Jul 2013
                          • 23
                          • Portugal
                          But can't be a lvds display cable?
                          • jtamad44
                            • Apr 2013
                            • 145
                            • israel
                            if its lvds cable just pure white on screen without stains.
                            • DJduck
                              • Dec 2012
                              • 229
                              • Estonia
                              Move the screen and see if anything changes. Did you replace that blown component next to the cable? That might be an issue.
                              Post a picture of the screen. I they are "artifacts" then you have a bad video chip. I had a Dell XPS M1530 that stripes and spots on the screen (the panel was fine) but it worked with an external monitor.
                              • jpdo
                                • Jul 2013
                                • 23
                                • Portugal
                                hi.
                                Now my keyboard isn't working fine.
                                The 'P' Key and caps Lock Key doesnt work. And the AHT says that dont have any problem with logic board.
                                Anyone can help-me? What i need to check?
                                Another Problem is the display, i replace the lvds cable and continues with backlight but no picture, can be the component that i have missing?
                                • crazypepe
                                  • Oct 2012
                                  • 34
                                  • Philippines
                                  Hi Sir!
                                  I am having the same issue with my macbook pro a1278 not charging I have changed the charger and the battery and tried resetting the smc still the same. I also swapped the magsafe terminal with a working one but still no charge. Whats was your solution?
                                  thanks in advance!
                                  • cyberhack
                                    • Feb 2013
                                    • 466
                                    • Uk
                                    here
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • korben_dallas
                                      Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                      by korben_dallas
                                      Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                      I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                      I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                      MY QUESTION:
                                      I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                      02-14-2024, 12:23 AM
                                    • Stephen
                                      A2991 Logic Board issue, 20volts 0 amps help!
                                      by Stephen
                                      Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                      09-10-2025, 03:16 PM
                                    • Stephen
                                      A2991 logic board issue, 20volts 0 amps help!
                                      by Stephen
                                      09-10-2025, 03:15 PM
                                    • tony359
                                      2007 Macbook logic board fault
                                      by tony359
                                      Good day all,
                                      I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                                      Once the fan was swapped, I installed an OS and it worked fine.
                                      The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                                      Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                                      If I see that right, I have missed VCORE on L7100 (page 59)....
                                      01-23-2025, 06:59 AM
