System not working after removing the NEC/TOKIN
  • rafemuhammed
    • Jul 2013
    • India
    I removed the NEC/TOKIN 0E907 to replace it with 4x330uF from Toshiba L300. Unfortunately, I lost the 330uF capcitors and waiting for another shipping. Will laptop works with out NEC/TOKIN 0E907?. My laptop is now turns on but nothing is coming to LCD and feels like dead. Is this lacks of NEC/TOKIN or another issue with LCD screen. LCD was working before the removal of NEC/TOKIN.
    One more doubt, Can I use normal cylinder capacitors instead of 4x330uF tantalum?
    Pls help
  • tomodachi
    • Apr 2012
    • 603
    • Turkey
    Re: System not working after removing the NEC/TOKIN
    Same happened to me last week, mine was working but not showing display, I replaced nec/tokin with 4 x 330 and result was perfect, for your case I guess your customer gotta wait for that cap, good luck !
    • rafemuhammed
      • Jul 2013
      • India
      Thanks for the reply...
      The 33uf tantalum capacitor is rare in my place.
      Can I use any other capacitor instead of 4x330uF tantalum?
      Regards..
      • tapasxplore
        • Jun 2013
        • India
        you can use two 470uF cap for this purpose. you can use ' rs components ' to get the mention caps. website is// in.rsdelivers.com , part no 737-2832. The caps will come to your place in about 7 days any where in India.
        If you have problem you can contact me at tapasxplore@gmail.com.
        I have also gone through the same problem.
        • masud
          • Jul 2011
          • 317
          • Bangladesh
          s8=470mf
          • guruji
            • Oct 2012
            • 120
            • India
            Hello
            By the way u are suppose to put 3caps of 330uf as your prodalizer is 907uf so 3 cap is enough.for a prodalizer nec tokin 1e28 =1280uf u use 4caps of 330uf.incase u want orignal i have in stock the nec/tokin.
            • guruji
              • Oct 2012
              • 120
              • India
              The 330mfd have to be 2volt rated and highest esr they only work
              • spleenharvester
                • Mar 2010
                • 903
                I've done this 3 times now, and can tell you it will not work without NEC/Tokin - it will power up and that's as far as you'll get. Same will happen if there is a bridge between the positive and negative caps.
                Also, use tantalums, don't use the "cylinder" electrolytic caps since they are of a high ESR. On my OE907 I used 4x330uF 2.5v 6mOhm ESR caps.
                Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                • rafemuhammed
                  • Jul 2013
                  • India
                  I have ordered tantalum capacitor from rscomponents(http://in.rsdelivers.com/) but after a month they are saying they dont have service station in my place to deliver the product. I decided to select tantalum instead of NEC/TOKIN is the easiness in soldering. Can anybody send tantalum capacitor to me so that I can pay you or can you pls tell other good site to order it. I only like cash on delivery for secure transaction
                  • alihomee
                    • Dec 2012
                    • 1577
                    • malaysia
                    you can get those caps from any laptop scrape motherboard if you have one.when i need to change this cap i never order on internet but only i take them from any old motherboard.
                    • spleenharvester
                      • Mar 2010
                      • 903
                      Yup, buy something like a faulty 6735s board, they have 4x330uF on by the CPU.
                      • Chaks
                        NEC TOKIN 0E907 Fault in Toshiba L510 Laptop - Can I use any of these caps
                        by Chaks
                        My old Toshiba L510 Laptop which was working fine with Ubuntu 22 Server till couple of days back. But suddenly I got a blank screen with fan spinning and no HDD activity. I tried all options and zeroed to a suspected/faulty NEC TOKIN.
                        So I removed the faulty NEC TOKIN 0E907 and want to know if I can use the capacitors I have salvaged from old Motherboard. These caps are from old Mackbook Pro Motherboard and I am not sure if any of these caps will work.
                        Can anyone please guide me....
                        09-12-2024, 12:06 PM
                      • ygorsan
                        by ygorsan
                        🧩 Problem Summary:
                        • I
                        07-28-2025, 08:34 AM
                      • ChaosLegionnaire
                        cracked tantalum cap on a video card. safe to apply power without fireworks?
                        by ChaosLegionnaire
                        please refer to the attached pics. is it safe to apply power with that tantalum cap like that without causing fireworks? i dont wanna burn a hole through the pcb as the gpu chip is on the other side.
                        happened to me once before with a shorted mlcc. shorted mlcc on a vrm power phase burned a hole through the pcb power section but thankfully that was nowhere near the gpu chip. but the video card still ended up in the landfill anyway tho as the burn-through was not fixable.
                        so do let me know what u think of the chipped tantalum there. thanks....
                        09-08-2024, 07:05 PM
                      • howardc64
                        Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                        by howardc64
                        TV was fixed just after removing Samsung's rear snap cover.
                        This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                        Maybe PSU->backlight connector didn't have a good contact?...
                        07-23-2025, 12:34 AM
                      • mustardcheese
                        Question about removing the BIOS lock
                        by mustardcheese
                        Hi all, I have a Dell Latitude 7300 with a locked BIOS and I was curious about the process of removing the lock by editing the hex values of the bin and how to do it. Is editing the hex values of the dumped bios any different than flashing a new one that's already been unlocked? (I currently don't have the correct bin because I realize I accidentally dumped the wrong thing). I am very new to this any help or advice or references would be greatly appreciated. Thanks
                        06-17-2025, 10:25 PM
