Lenovo B560 fluctuating DC
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    I got this laptop where The voltage at D1(see page 46 in the attached schematic diagram) is fluctuating. Using power adapter,
    What i tried:
    1. TPS51123 is overheating so i replaced it with a new one.
    2. tested the mosfets, no short found.
    Havent tested the board using the battery. Any idea where the problem is? I also have acer 5570 zr1 with similar issue.
  • jtamad44
    • Apr 2013
    • 145
    • israel
    Re: Lenovo B560 fluctuating DC
    try everything you know and if the problem stll the same post back everything you did in the past.
    • tomodachi
      • Apr 2012
      • 602
      • Turkey
      Try to desolder these coils one by one and measure if there is a short
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        Thank you for your reply.
        I already measured the resistance from those those coils to ground but there are no short. Tried replacing U7 - BQ24745 charger IC but same problem. the voltage at D1 fluctuates wildly. I will try to remove U38 and U37 and post bact the result.
        • Techie666
          • Feb 2013
          • 23
          • Mexico
          Have you tested the dc adapter? I would put a load on the adapter alone (connect a 12v fan or something) and measure with volt meter to see if the voltage goes down. it should stay steady at almost the rated voltage. if voltage drops more than 1 volt try another adapter.
          • whaldsz
            • Apr 2013
            • 395
            • Philippines
            Yes, adapter is fine. Tried another known good adapter still the same.
            I will try to remove the coil as suggested by tomodachi and measure the voltage across D1, will post back the result.
            • nataf10
              • Mar 2012
              • 37
              • Israel
              Hi there!
              I have also a dead motherboard that not power on.
              Have you fixed your at last?
              Can you please upload or send me the correct schema for this LA56 mother board?
              Please advise.
              Regards.
              • tiak
                • Sep 2013
                • 50
                • Iran
                Where is : attached schematic diagram ?
                • BenCesur
                  • Jun 2011
                  • 35
                  Hey.
                  I need this scheme. (b560) Would you please add?
                  Thank you.
                  • ravindra
                    • Sep 2014
                    • 3
                    • india
                    I have same Problem. My laptop suddenly died, no warning that I could see, I was watching a video and wasn't paying the best attention, but there were no noises. The screen just went black and the computer died.
                    The orange light on the power adapter is solid when it's not plugged it, when it plugs it, the light goes out and then blinks twice, dark for a second, then blinks twice again and repeats.
                    Please help me, and also please provide me it's schematic diagram, if some one have
                    Thank you
                    • cyberhack
                      • Feb 2013
                      • 466
                      • Uk
                      • attila123
                        • Jun 2014
                        • SLovakia
                        Hi guys!
                        I have big problem with a Lenovo B560 with LA56 MB motherboard. I probably shorted out the LVDS connector at display. When I tried to turn on the notebook nothing happened, only power led is flashing very slowly. When I plug in AC the power led starts flashing every about 10 sec for 1 sec or less, no fan is working.
                        How can I fix it? Which power IC could damaged?
                        Thank you!
                        • rajeshkumar
                          • Oct 2014
                          • 44
                          • india
                          hiiiiiii frnd need b560 la56 schematic diagram
                          dimm display problem facing
                          • emr2000
                            • Mar 2015
                            • 17
                            • turkey
                            b560 diagram
                            • angel-boy
                              • 550
                              • Romania
                              Hi friends, I have a problem with the motherboard laptop lenovo b560
                              - i have 3 boards, all power on , but when i want to shutdown , when power led from power button and power led near charge led, remains on !
                              - i change the bios same problem , i dont know what to do !!!
                              about the problem - http://*******/viewtopic.php?f=58&t=23204
                              If you have an account please give me some bios ,i dont have enough posts to download bios
                              • dj_ricoh
                                • 2073
                                get the files from there if you can!
                                • angel-boy
                                  • 550
                                  • Romania
                                  Did you read ? " If you have an account please give me some bios ,i dont have enough posts to download bios "
                                  i cannot get files from there. if someone can help me , please help me .
                                  • khaahk
                                    • Dec 2013
                                    • 760
                                    • Estonia
                                    from another source but also for LA56
                                    • angel-boy
                                      • 550
                                      • Romania
                                      you give me EC , not main bios, please if you have a working bios file , from a lenovo thats shutdown
                                      • angel-boy
                                        • 550
                                        • Romania
                                        I partial solve the problem of lenovo, now is shutdown , but when power up , lenovo logo appers late, and the fan allways is on.
                                        • Cemal Odabasioglu
                                          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                          by Cemal Odabasioglu
                                          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                          Observations...
                                          01-14-2025, 03:54 PM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
                                        • derradji89
                                          Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                          by derradji89
                                          Hi everyone 🤗
                                          I have a Lenovo MIX 320-10lCR computer.**
                                          1. **Operating System**: Windows 10 ** Education** 64-bit.
                                          2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                          3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                          4. **BIOS Chip Reflashing**: Currently,...
                                          04-19-2025, 03:04 PM
