Locating short circuits with bnch psu
  • scobie_21
    • Jul 2011
    • 144
    Re: Locating short circuits with bnch psu
    I think maybe this is just a crap PSU heres the link to the exact model
    http://www.gotronik.pl/zasilacze/pxn1505.html
    • scobie_21
      • Jul 2011
      • 144
      Would anybody have a manual for this or similar unit ? Also is the C.C led on the current supposed to be on all the time ?. The C.V led is always off on the Voltage. Could this unit be faulty I only bought it this week?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        C.C. light on means it's current limiting. Are you sure you have set the current limit correctly? It should only go on when you short the output, or apply a load in excess of what the PSU can provide. With an open circuit output, the C.C. led should never come on, instead the C.V. one should be lit.
        We have the same power supplies in the lab at uni and they work just fine, maybe you got a dodgy one. You may have to return it.
        A working TV? How boring!
        • scobie_21
          • Jul 2011
          • 144
          Yeah I think you are right about it being faulty. When its switched on it automatically shows red C.C led and if you try adjust it just stays 0.00 if you short out the leads both voltage and current go to 0.00 and the C.C led turns green. You then have to turn off the psu before it will do anything else.
            To set the current on most lab power supplies short the output terminals.
            Reminds me of my lab lecturer freaking out when I did this trying to set the current. He said it would blow the fuse. It didn't, it is how you do it (set the voltage lower so you don't get a spark from the capacitor on the supply's output but otherwise there shouldn't be an issue.)
            • scobie_21
              • Jul 2011
              • 144
              #26
              Yeah but that's the problem as well there is no way of adjusting the current it doesn't respond to adjustment when shorted. If you connect to dc motor and increase voltage it will showing the change of current but theres no way of controlling it.
              • smason
                • 1652
                Definitely broken.
                Take it apart, might be something simple like a loose wire, bad solder joint, you might get lucky.
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  #28
                  Originally posted by scobie_21
                  When you say you try to stay under .5A how do you control this ? I don't seem to have any current limit on my supply It just goes straight to protection mode and I have to switch of the bench psu then on again so theres no chance to find components heating up.
                  I start at zero volts then increase it gradually. If the shorted component has a very low resistance like below 0.1 ohm, its difficult to make it heat up noticeably.
                  I use the millivolts range on my multimeter to find the area on the rail with the lowest voltage reading. My meter only has 100uv resolution, so its not much good for finding a short on a power plane.
                  I have found that shorted surface mount ceramic capacitors change resistance slightly when heated with a soldering iron.
                  • aspire550z
                    • Oct 2011
                    • 5
                    • TM
                    #29
                    for a cheap and reliable psu i think this may be a good buy....http://www.attenelectronics.com/Prod.../0728/104.html i use it since 7..8..month ago without any problem...apart from noisy cooling fan..(i had replaced it with new)..btw..i'm not from atten...
                    • sasser
                      • Dec 2012
                      • 365
                      • Malaysia
                      #30
                      with bench PSU also we know current input. almost below 5A. if current got 1.000A above some issues with bga power. anyone agree with my theory ?
                      • popeye
                        • May 2011
                        • 155
                        #31
                        When using bench power supply to fault find short set current limit to0.5A @1V to start if there is a short componants should heat up after a while you can increase the voltage but not too high as if one of the supply mosfets or regulators are short if you find south or north bridge getting hot switch off imeadiately or you may end up putting 19v through one of the bridges or CPU
                        the machine would then be scrap.
                        • sasser
                          • Dec 2012
                          • 365
                          • Malaysia
                          #32
                          popeye u mean slowly up the volt from setting 5A with 1v ? then up the volt till getting hot? i always set actual volt 19.5v then see the current come in.
                          • fddizon
                            • Sep 2011
                            • 555
                            • Philippines
                            #33
                            181188333005 this might find you interested...
                            sasser, popeye is right. that is the way
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              An EE friend of mine wanted me to get a 'proper' bench psu, but I am still hesitant, because of all the crappy, cheap chinese ones on ebay! XD
                              Muh-soggy-knee
                              • popeye
                                • May 2011
                                • 155
                                #35
                                Hi
                                the setting for current is 500mil amp half of an amp any more and you risk damaging the board beyond repair. this setting is only for when you have a short circuit before the voltage goes from KBC.
                                • sasser
                                  • Dec 2012
                                  • 365
                                  • Malaysia
                                  #36
                                  popeye just double confirm to set adjustable psu with start 1v and 0.500A how about if the laptop in s5 need fully loaded 19v? or u mean just only 1v is enough to see either mosfet or regulator hot?
                                  • DynaxSC
                                    Extreme High Current & Low Voltage Short Killer ??
                                    by DynaxSC
                                    Hi Folks
                                    I'm looking for a extreme high current short killer solution for a reasonable cost.
                                    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                    After taking off the socket, the shorts dissappear again.
                                    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                    10-15-2024, 10:13 AM
                                  • Stephen
                                    MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                    by Stephen
                                    I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                    02-06-2025, 12:03 PM
                                  • adelfr2009
                                    HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                                    by adelfr2009
                                    I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                                    After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                                    09-28-2025, 10:21 PM
                                  • Geeker007
                                    9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                                    by Geeker007
                                    Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                                    I am new to electronics repair, so my queries could be naive but I am ready to learn.
                                    So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                                    01-28-2025, 03:31 PM
                                  • kotel studios
                                    Lenovo B50-70 LA-B092P REV 2.0 - short on +3VLP
                                    by kotel studios
                                    My lenovo B50-70 laptop (mainboard compal LA-B092P VER 2.0) had a short on the +3V generation part (where PU401 is).
                                    I've removed the SY8208BQNC and the short is gone on PL402. Although, it's still there on pin 5 "LDO" of the SY8208BQNC (1.8ohms to GND).
                                    All other coils aren't shorted to GND.
                                    Removing the PC412 cap didn't help. Mainboard pads are still shorted. Cap itself is fine.
                                    Pin 20 (+3VLP) of ALC codec isn't shorted too, so it shouldn't be the issue.
                                    Originally, the laptop wouldn't power on. It would get its 20V on the...
                                    10-12-2025, 03:32 AM
