USB ports not working on Advent
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    hi guys bought the girlfriend a Advent Veroa I30IL1 , problem is the USB ports are not working. i opened the thing up and there was a ribbin coming from the motherboard to the USB ports so i ordered new usb ports and cable online, got them through. after replacement i switched laptop on and again no luck > what could be the problem guys
  • selldoor
    Slow Learner
    • 7870
    Re: USB ports not working on Advent
    Post a really clear picture of the area of the motherboard where the usb connector is.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      hope these are clear enoug mate ?
      • selldoor
        Slow Learner
        • 7870
        Assuming you are using windows does the usb controller show in device manager
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          in the device manager it shows as USB controllers but when i plug something in get abso nothing. tried it with a USB drive to see if it would show up in system management but doesnt show ??
          • selldoor
            Slow Learner
            • 7870
            Hopefully someone will have working knowledge of the problem only other
            thing I can think of is , is the cable the right way up in the connector.
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              yeah mate tried it both ways
              • selldoor
                Slow Learner
                • 7870
                Tried uninstalling all the controllers in device manager then rebooting to re install. Update the bios?
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  first find the schematic, then measure usb ports + - and 2 data pin (middle two pins) but i think, in your case, +5 v is missing. check schematic find +5v trace the circuit find the failure and fix it or get +5v (stable)from nearest 5v switch to usb + pin. make sure if it is always on.
                  • spleenharvester
                    • Mar 2010
                    • 921
                    Are you sure that ribbon's in all the way matey? It doesn't look like it is in the picture.
                    EDIT: Nvm looks fine from another angle :p
                    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      will try that when i get the thing back together and update you
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        dont know if this is relevant guys as ive not noticed any other problems as of yet but as i was putting the laptop back together i noticed a burn mark on the ribbon of the touchpad , looked on the motherboard where the ribbon goes to on the opposite side and this is what i seen, looks like something is burnt out even through the plastic sheet that covers the motherboard.!
                        • cheapie
                          null
                          • Jul 2010
                          • 849
                          I think that would be the problem.
                          • fddizon
                            • Sep 2011
                            • 555
                            • Philippines
                            you will need the schematic for that lappy. and find out what the part number and replace that
                            • selldoor
                              Slow Learner
                              • 7870
                              Yeh - that would do it!! could be a 5v voltage regulator. can you post a close up picture of it. Can you read any numbers on it. Tak a pic and read what you can then get some Isopropyl alcohol and try and clean it to see if it reveals any more.
                              • spidey
                                climbs
                                • Dec 2012
                                • 644
                                • Cyprus
                                i allready told you what to do.
                                • DJduck
                                  • Dec 2012
                                  • 229
                                  • Estonia
                                  Don't touch the dead chip, you might accidentally scrape off the part numbers (this burnt shit will come off very easily).
                                  I can put text here?!
                                  • fddizon
                                    • Sep 2011
                                    • 555
                                    • Philippines
                                    spidey,
                                    are you trying to tell us that even he will not replace the burnt part, he can fix it by tapping from a 5 volts stable supply?
                                    tnx
                                    • spidey
                                      climbs
                                      • Dec 2012
                                      • 644
                                      • Cyprus
                                      Originally posted by fddizon
                                      spidey,
                                      tnx
                                      Yes, if it is the +5v switch (the burnt ic), desolder it and just apply +5v.
                                      • DynaxSC
                                        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                        by DynaxSC
                                        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                        The board is generally working now, all PCIe ports are working, Windows installs normally.
                                        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                        03-10-2025, 12:27 PM
                                      • Fluxi_77
                                        HP 355 G2 Left USB Ports and Ethernet Port not working
                                        by Fluxi_77
                                        Hello Guys,
                                        I currently have a problem with an HP 355 G2 where the right USB Port works without a Problem but the left ones and the Ethernet port which is also in the region of the two USB ports are not working.
                                        The HP Hardware Diagnostic tool also shows them as faulty. I used a USB tester and it also shows that I don't have 5V on the ports so I suspect a problem with an IC that controls the Voltages that goes to this ports.
                                        Unfortunately I found no boardview or schematic for this device and I am a newbie in tech repairs so I don't know where to start. Other than this problem...
                                        02-19-2025, 12:29 PM
                                      • techpointhull
                                        S3 Graphics LS3440 - Analogue not working on both DVI-I ports
                                        by techpointhull
                                        Hi Guys,
                                        Weird one here. I have a special GPU made by DFI (Model LS3440) from an Arcade gaming machine. The GPU uses the S3 440 GTX Chipset, and has dual DVI-I ports. For some reason, the analogue has stopped working on both outputs (DVI-I to VGA cable). DVI-D and digital outputs work fine, just the analogue that has stopped working.
                                        Now, I could get around this by using Active cables to convert the signal over to Digital, but its got me wondering exactly what the issue could be. I have inspected the GPU and DVI ports under my microscope, but nothing stands out. Because...
                                        12-06-2023, 10:30 AM
                                      • MichelinMan
                                        CF-20 Toughbook (mk1) Trackpad/Touchpad and USB ports not working
                                        by MichelinMan
                                        Hey guys,
                                        Just purchased a CF-20 (mk1) supposedly was all working. However, the seller had done a fresh install of windows 10 but did not install any driver. Seller was adamant the trackpad/touchpad was working.
                                        The touchpad/trackpad does not work. No led lights near the trackpad. The keyboard works, the USB 2 port on the base does not work, The USB 3 ports will recognise a USB 3 flashdrive but did not recognise a USB mouse. The ethernet port on the keyboard section works.
                                        The USB 3 port on the actual tablet section works with no issues.
                                        07-18-2023, 08:12 AM
                                        Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                        09-06-2024, 09:40 AM
