MacBook Pro 2008 no power after reball
  • lord
    • May 2011
    • 319
    • Croatia
    I had this problem many times, and i never resolved the problem.
    So as you would know this series of macbooks have a huge problem with graphics (G84-602-A2), and the reball would fix the problem. So, i did a reball on the board for the THIRD time and now it just doesn't respond to the power button.
    Has anybody had the same problem?
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: MacBook Pro 2008 no power after reball
    reball it the fourth time
    • thesloc
      Banned
      • Dec 2011
      • 587
      Could be that you fried the GPU.
      Consider buying another one and simply attaching it.
      Also, since the NB and CPU are pretty much attached to the motherboard, there's a possibility those have come loose after all those re-balls.
      Just a thought.
      • lorins_core
        BlackSmith
        • Dec 2012
        • 551
        • Philippines
        I have A Idea... Can you Try To little bit Shake The GPU In Heating Using Infra. somethimes the BGA ball are not Align Proper? I hame many Expirence Before...
        • siddiq
          • Dec 2011
          • 121
          • Ghana
          Measure the resistance across the capacitors on the GPU after lifting and if you get absolute zeros on any of the them then the GPU is definitely fried and like thesloc said consider buying another one and simply attach it.
          • lorins_core
            BlackSmith
            • Dec 2012
            • 551
            • Philippines
            double check? if the cpu chip have no physical bubble it is ok but if have i thinking 50/50 chances to power up or diisplay... that my expireince
            • lord
              • May 2011
              • 319
              • Croatia
              I have couple od GPUs already, buy them before, since this MacBooks are prone to GPU cold joints.
              So i tried with 3 GPU-a, reballed again and again on couple of MacBooks, even reballed the northbridge, southbridge and the CPU. Yesterday reballed KBC....
              • thesloc
                Banned
                • Dec 2011
                • 587
                bad memory perhaps? try swapping it out just in case.
                • lord
                  • May 2011
                  • 319
                  • Croatia
                  Tried RAM preplacement, although with bad RAM the laptop should turn on
                  Cmon, somebody should know about this error!
                  • xboxhaxorz
                    • Jan 2011
                    • 196
                    i hate macs but i will post for general laptops with no power after reworking
                    if it had power then there is a 99% chance that you have a bridge or short underneath the bga or the chip is dead
                    if the laptop does have dedicated video you can remove the gpu and test it should still have power
                    but i have no idea about macs proprietary pos
                    • SarcasticOP
                      General question about MacBook power rails for repair.
                      by SarcasticOP
                      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                      • PPBUS_G3H (12.6V-12.8V)
                        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                      • PP3V42_G3H (3.42V)
                        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                      • PPVRTC_G3H (3.3V)
                        • This
                      12-12-2024, 05:50 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • bcstedt
                      LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
                      by bcstedt
                      LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
                      Problem:
                      On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
                      It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
                      01-18-2024, 01:03 PM
