HP530 Not Charging
  • ft102man
    • Feb 2013
    • 4
    • England
    HP530 Not Charging
    hello all
    I got a hp530 on fleabay recently for a few bucks just for the screen really but the guy sent all the motherboard etc so I reassembled it all tried to power up but it would shut straight down. On further investigation I for PQ 3 to be burn't out of all recognition lucky I had a another faulty mobo. I replaced the ao4407 & to my joy the machine powered up stayed on until I pulled the charger plug out. Does anybody know which other mosfet stop the thing running & charging the battery please or does anybody have a schematic of the power/charging circuits on the mobo.
    Stan
    England
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: HP530 Not Charging
    try to change 2 mosfets. usually if the one is bad the other is also bad.
    • ft102man
      • Feb 2013
      • 4
      • England
      hi
      which 2 mosfets PQ? & PQ?
      I already changed PQ3 do you mean PQ4 on the other side of the board?
      thanks
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        usually there 2 mosfets connected. i need to see the schemtic or pic. i'll try to find the schematic tomorrow.
        • ft102man
          • Feb 2013
          • 4
          • England
          yeh I seen the schematic and it is PQ4 connected to it on the opposite side of the board. Can you confirm this so I don't look a complete idiot!
          thanks
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            its 01:32 am here now, morning when i arrive to work i'll find the schematics then i can confirm.
            • ft102man
              • Feb 2013
              • 4
              • England
              ok fine you better get to bed then!
              cheers
              • coasterghost
                Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                by coasterghost
                For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                System Hardware:
                Processor: AMD Ryzen 7 PRO 5850U
                Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                09-08-2025, 10:46 PM
              • Thomasraud
                Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                by Thomasraud
                i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                QUOTED
                -It works on charger (without battery connected-only charger)
                -It works on battery (without charger connected-only battery)
                -& it also works when plugged in battery & charger, but it's not charging the battery
                //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                and..
                QUOTE
                The IC cannot maintain the input current level
                06-28-2022, 06:47 PM
              • Scoff
                HP Probook 470 G4 - Power and Charging Problem
                by Scoff
                Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                07-03-2023, 09:28 AM
              • SluggerB
                Help with trying to fix phone that is not charging (Pics inside)
                by SluggerB
                I have two TCL A30 phones.
                Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                New Phone: Works fine, bought as a donor board to try and repair Old Phone
                My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                08-12-2024, 08:11 AM
              • Wang Tingting
                Acer Nitro 5 AN515-57-536Q not charging
                by Wang Tingting
                I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
                report is also good for battery.
                Following https://www.badcaps.net/forum/troubl...arging-circuit,
                • DCIN/VCC: 19.1
                • ACIN/ACDET: 3v
                • REGN/VDD: 6v
                • CMSRC : 19v
                • ACOK: 3.3v
                • ACDRV: it is 19v, not 25V(when charging, the ACDRV
                09-10-2025, 01:46 PM
