DV4-1435DX dead
  • salawayon
    • Nov 2012
    • 578
    • philippines
    DV4-1435DX dead
    no charging light at charging port, won't power up, switch is ok.
    tried already changing the charging pin (whole assembly).
    tried already replacing the ENE KB926.
    5vdc and 3.3vdc are measurable, 3.3vdc at power switch is present.
    i'm also requesting for the schematics...
    board: JAL50LA-4101P Rev. 1.0
    thanks...
  • opamp
    • Dec 2012
    • 160
    • united states
    Re: DV4-1435DX dead
    Check page 5 of the schematic it will show you the power on sequence on.
    • salawayon
      • Nov 2012
      • 578
      • philippines
      Re: DV4-1435DX dead
      Thanks for the schematics.
      Initial info I got:
      Pq103-19.88vdc
      Pin4-8.44vdc
      Pu102 - (393)
      Pin1 - 3vdc
      Pin2 - 1.2
      Pin3 - 1.4
      Pin4-0
      Pin5-19.28
      Pin6-3.28
      Pin7-1.2
      Pin8-1.8
      PD1- 3.28vdc
      PQ110 - no voltage reading at all pins.
      PU101 - (BQ24740)
      ENE KB926QF
      Pin32 - 2.6vdc
      Pin33 *- 3.33vdc
      Pin97 - 2.6vdc
      PQ102 (4407A) or fds6675bz
      Pin1234 *- 19.8vdc
      BTW, when does the blue led will lite up at charging pin?
      • heavymachines
        • Mar 2011
        • 1028
        Re: DV4-1435DX dead
        most likely an reflow issue welcome to hp....even thou they have a lot of power issues as well i am betting on reflow with any dv series hp....
        • salawayon
          • Nov 2012
          • 578
          • philippines
          Re: DV4-1435DX dead
          this is intel chipset mainboard that mostly doesn't have videochip problem due to over heating. i only encountered once with Compaq F700 with Nvidia Videochip, no lights at all and won't power up. after reflowing the nvidia chip it power up.
          • opamp
            • Dec 2012
            • 160
            • united states
            Re: DV4-1435DX dead
            Initial info I got:
            Pq103-19.88vdc
            Pin4-8.44vdc
            Pu102 - (393)
            Pin1 - 3vdc
            Pin2 - 1.2
            Pin3 - 1.4
            Pin4-0
            Pin5-19.28
            Pin6-3.28
            Pin7-1.2
            Pin8-1.8
            PD1- 3.28vdc
            PU101 - (BQ24740)
            ENE KB926QF
            Pin32 - 2.6vdc
            Pin33 *- 3.33vdc
            Pin97 - 2.6vdc
            Pin1234 *- 19.8vdc
            The charging light should be present when power is ok. Ene ic has more than 3 voltages make sure they are all present also LM393 should have voltage like this:
            1)3.3v
            2)1.2v
            3)1.4v
            4)0v
            5)1.8v
            6)1.2v
            7)3.3v
            8)19v
            • heavymachines
              • Mar 2011
              • 1028
              Re: DV4-1435DX dead
              well intel and ati has reflow problems too its not limited to nvidia , one thing they have in common is no lead soldier oh yeah xbox rrod has that in common as well...again no lead soldier ...and many tv's have that problem on their mainboards.... i have had to reflow all but tv's so far...but best way is to reball.. still have to master that skill....
              it all comes down to how hot it got......plugged heat sink or heat stress marks on gpu and cpu are sure fire sign it got hot...
              but their is a chance its a power issue i would not rule that out entirely either...
              here are different reflow symptoms i delt with... no power, power on no video, power on boots but no wireless, turns on shuts right back off, turns on no video to it's own display but will display to vga output... it all depends on what pins came disconnected under the bga chip could be gpu could be south bridge.......and somebody else here not too long ago had one where it would not show dvd drive and it was an hp dv series.........
              • salawayon
                • Nov 2012
                • 578
                • philippines
                Re: DV4-1435DX dead
                1)3.3v
                2)1.2v
                3)1.4v
                4)0v
                5)1.8v
                6)1.2v
                7)3.3v
                8)19v
                PU102 is LM393 in my post. All voltages are present.
                • opamp
                  • Dec 2012
                  • 160
                  • united states
                  Re: DV4-1435DX dead
                  No they are not recheck and compare. Check the resistors around LM393.
                  • salawayon
                    • Nov 2012
                    • 578
                    • philippines
                    Re: DV4-1435DX dead
                    What do you mean recheck and compare? The posted values were the actual readings that I got. Tried already replacing the LM393 but same status.no light at charging pin.
                    • degutji
                      • Dec 2012
                      • 173
                      • Indonesia
                      Re: DV4-1435DX dead
                      Maybe this is what opamp mean ,
                      Pu102 - (393) Salawayon test
                      Pin1 - 3vdc
                      Pin2 - 1.2
                      Pin3 - 1.4
                      Pin4-0
                      Pin5-19.28
                      Pin6-3.28
                      Pin7-1.2
                      Pin8-1.8
                      Opamp -> The charging light should be present when power is ok. Ene ic has more than 3 voltages make sure they are all present also LM393 should have voltage like this:
                      1)3.3v
                      2)1.2v
                      3)1.4v
                      4)0v
                      5)1.8v
                      6)1.2v
                      7)3.3v
                      8)19v
                      Compare by yourself , see the red marking
                      • opamp
                        • Dec 2012
                        • 160
                        • united states
                        Re: DV4-1435DX dead
                        Ok I see what you are doing. All so-8 package chips have pin 8 across pin 1 now you say PD1 has 3.3 volts?? I think you mean PD104 and that diode should be 19v. Check pin 25 on ENE.
                        • RobRocks
                          • 13
                          Re: DV4-1435DX dead
                          Hello, if all voltages seem ok, flash bios, if still not working, replace kbc, still not working replace clock generator. check if laptop drains more current then 0.01A? At least if voltages are ok, bios ok, kbc ok charging light should come, battery should charge. Check if acin acdetect is working, i think there wa resistor somewhere which likes to go up in value so the adaptor is no more detected, check the schematic.
                          • double_DD
                            How can I be sure that my EC chip is dead?
                            by double_DD
                            As the title suggests, how can I be sure that my EC chip is really dead?
                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                            03-12-2025, 07:47 AM
                          • disorder
                            ps5 edm-033 dead after hdmi/usb ports destroyed
                            by disorder
                            hello guys,
                            i need help to repair a edm-033 ps2
                            history : as always hdmi port and usb ports destroyed after unplugged
                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                            so i changed it
                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                            i don't see any projection of liquid metal on pcb.
                            01-14-2025, 12:48 PM
                          • zunasthegreat
                            Chieftec GPS-450-AA with dead 20N60C3
                            by zunasthegreat
                            Hello everyone hope all doing well!
                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                            09-01-2024, 07:12 PM
                          • Beton
                            Finding a dead short component
                            by Beton
                            Hi guys!
                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                            I have a bench PSU and if I try to inject voltage the voltage...
                            12-10-2021, 01:05 PM
                          • FiguringITout
                            MSI Raider GE75 - Not posting, probable dead CPU
                            by FiguringITout
                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                            07-25-2024, 07:27 AM
