HP pavillion dv6 wont boot
  • hienton2
    • Sep 2009
    • 183
    I am working with HP dv6. All led lit . Hardrive spin. but never have screen picture light. Error led blinks 3 times. I already clean rams and socket. No help.
    Any body has idea? TIA
  • DerStrom8
    Techie
    • Dec 2012
    • 76
    Re: HP pavillion dv6 wont boot
    I have a similar problem with my HP dv2500. It could very well be a problem with the NVIDIA display chip. They're notorious for bad solder joints that come undone over time and kill the display. Your choices would be to do a reflow of the solder joints or purchase a new motherboard. Reflow is cheap, but there's the possibility that you'd damage components on the board. Buying a new motherboard is less risky, but costs more. Take your pick
    I wish you the best of luck.
    Regards,
    Matt
    • hienton2
      • Sep 2009
      • 183
      Already reflow but no help. Thanks Matt
      • DerStrom8
        Techie
        • Dec 2012
        • 76
        In that case, you'd be better off just buying a new motherboard. The joints under the chip are not set up in a way that you can really replace it yourself. You could take it to a pro, but it'd probably be cheaper to just buy a new mobo.
        Regards
        • hienton2
          • Sep 2009
          • 183
          This is northbrige ic Matt. I never install BGA ic. Need pro . I think I must look for a motherboard.
          • opamp
            • Dec 2012
            • 160
            • united states
            That's a memory error get the schematic and check for proper voltages to the modules. If evrything seems right replace the northbridge
            • DerStrom8
              Techie
              • Dec 2012
              • 76
              Thanks for looking that up. I didn't even think to
              Mine's definitely different then. I'm 99.99% sure the error i'm getting has to do with the video card (chip).
              • opamp
                • Dec 2012
                • 160
                • united states
                What's the model number?
                • opamp
                  • Dec 2012
                  • 160
                  • united states
                  • hienton2
                    • Sep 2009
                    • 183
                    It is dv6-1243cl
                    • opamp
                      • Dec 2012
                      • 160
                      • united states
                      It looks like the cpu has an integrated memory controller. Try changing the cpu if the memory slots have the appropriate voltage on them.
                      • opamp
                        • Dec 2012
                        • 160
                        • united states
                        Hey Matt, I know what you're saying those nvidia chips are a real pain the only way to really fix them is to replace them with a new one.
                        • nish_pinto
                          The Adventurist
                          • Oct 2011
                          • 83
                          • India
                          If you want to save some bucks, you better Reball that nvidia chip. Even if you replace that motherboard, you'll get the same problem after certain usage time.
                          http://nishantpinto.blogspot.in/
                          • Joseph67
                            • Feb 2011
                            • 37
                            Re: HP pavillion dv6 only boot sometimes
                            Hi, my Pavillion dv6 does boot sometimes but most of the time does switch off before getting to boot. I have measured the voltages on the filters and they seem OK, like 3V, 5V and 12V and that is after the power led goes off.
                            Even plugging it in the mains just to charge the battery has the same effect i.e. the power led goes off after a short wile. This particular board does not have an NVidia chip but an ATI so I don't think it has anything to do with the video chips.
                            Any ideas??
                            Thanks.
                            Joseph.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              It's the same thing with any BGA. The nvidia chips were problematic themselves, but any BGA can get unsoldered from the board. My money is still on the northbridge. Especially if it's AMD RS780M or RS880M, which i strongly suspect is the case in that model.
                              A working TV? How boring!
                              • Joseph67
                                • Feb 2011
                                • 37
                                Thanks for the suggestion.
                                I've got a HOZAN spot heater with some heads of the right size so I will have a go at re flowing the chip.
                                Cheers, Joseph.
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  reflow will no nothing to it
                                  just had same machine , fortunelty i had this ati chip in stock , and its not working , only after replacing new chip
                                  • senchire
                                    • Dec 2012
                                    • 190
                                    • Bosnia
                                    Yea its strange a bit with ati's 90% of the time I had to replace them because they just die.
                                    • Joseph67
                                      • Feb 2011
                                      • 37
                                      Hi, I've found a brandnew mainboard for $85,99 on Ebay. Company name is Ascendtech.
                                      Just replaced the board and running as new.
                                      I just used better thermal paste than HP did.
                                      I hope that this will make the difference in performance.
                                      Cheers.
                                      • privato89
                                        Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                        by privato89
                                        I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                        Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                        Let's begin:
                                        Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                        03-26-2024, 06:37 AM
                                      • hinisa
                                        Xiaomi router freezes at boot after re-capping
                                        by hinisa
                                        I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                        When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                        After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                        Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                        07-08-2023, 05:58 AM
                                      • Luke Anders
                                        Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                        by Luke Anders
                                        A few details about the laptop itself:
                                        Name: Lenovo Legion 5
                                        Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                        BIOS Version: GKCN60WW
                                        EC Version: GKEC65WW
                                        Serial Number: PF39AQ7Z
                                        Board Model: NM-D562 Rev 3.0
                                        RAM: 16GB Installed, DDR4 (brand new)
                                        NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                        I bought this laptop recently from eBay as a faulty device....
                                        10-12-2024, 05:13 AM
                                      • NolesFan
                                        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                        by NolesFan
                                        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                        10-24-2024, 06:36 PM
                                      • torchzack
                                        Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                        by torchzack
                                        Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                        I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                        Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                        08-28-2023, 07:42 AM
