Emachines D725 Keyboard and touchpad not working
  • Taxman
    • Nov 2012
    • 45
    Re: Emachines D725 Keyboard and touchpad not working
    Last thought. I wouldn't have expected this to affect the system when booting pre-Windows, but apparently it can - if you've inadvertently switched on Filter Keys you can lose access to the keyboard AND the mousepad.
    • valiant007
      Comp Technician
      • Dec 2012
      • 44
      • philippines
      its ok, im open to any suggestions. what do you mean by: ``if you've inadvertently switched on Filter Keys you can lose access to the keyboard AND the mousepad´´. i did not understand that sentence.
      _________________________________________________________________
      Free Computer Service!!!!!!!!!
      If We can´t Fix the problem.
      • goodbrethen
        • Dec 2012
        • 17
        • Philippines
        try to reset all the cable connection connected to keyboard and touchpad maybe it will help.
        • Taxman
          • Nov 2012
          • 45
          Filter keys is an option that makes typing easier for people with physical hand problems. It tells the keyboard to ignore brief or repeated keystrokes and means that keys need to be pressed for a longer time to respond. It can be switched on by pressing the shift key for 8 seconds and that can of course be done unintentionally - I heard of that supposedly happening when a cat walked on a keyboard.
          I believe the filtr keys option is only supposed to affect the keyboard but I've heard of it affecting the touchpad too.
          You can check if it's on and turn it on or off via the Accessibility options in the control panel.
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            valiant,
            why don't you try troubleshooting keyboard first.
            i suggest you download the net book schematic so you will clearly see where to start troubleshooting.
            regards
            • valiant007
              Comp Technician
              • Dec 2012
              • 44
              • philippines
              #26
              Originally posted by fddizon
              valiant,
              regards
              thanks for the suggestion, do you know a website where i can download the schematic for this laptop?
              • fddizon
                • Sep 2011
                • 555
                • Philippines
                #27
                will feed it here
                http://kythuatphancung.com/download/...chematics.html
                (bro, meron ba place diyan na makakamura sa overnight accommodation? hehehe plano pa lang this coming summer)
                • heavymachines
                  • Mar 2011
                  • 1028
                  Originally posted by valiant007
                  thanks for your advice, i tried booting it up on hirens but with the same result. seems to be a hardware problem. do you have any suggestions where i can check for the hardware prob?
                  its time to take it apart get the motherboard exposed and start checking fuses and continuity on ribbons and look for obvious shorts or corrisions...you will need a dmm
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    #29
                    well im not expert but after i tested it with another working keyboard i i would replace Keyboard Controller (KBC KBC773L)...
                    Im Back... sort of...
                    • fddizon
                      • Sep 2011
                      • 555
                      • Philippines
                      #30
                      that is a way too fast to conclude.
                      our friend here is trying to learn too.
                      kbc pins goes to kb connectors. it will be worth checking. also check for unusual on the chips pin.
                      if there are corrosion on pins, clean the pins with cleaner and tooth brush.
                      flux and heat, cool it, clean and test.
                      i bet you know what to do. i wrote just in case
                      regards
                      • valiant007
                        Comp Technician
                        • Dec 2012
                        • 44
                        • philippines
                        #31
                        will feed it here
                        thanks for this. it is greatly appreciated.
                        (Mail mo lang ako ng mga details para hanapan kita ng mura.)
                        • valiant007
                          Comp Technician
                          • Dec 2012
                          • 44
                          • philippines
                          #32
                          ok ill thy this suggestion. its just that ive been fixing laptops for some time now but i just started on board level repair recently so im quite new with this stuff. ill open it up try your suggestions. thanks again.
                          • valiant007
                            Comp Technician
                            • Dec 2012
                            • 44
                            • philippines
                            #33
                            i may consider this suggention sir but it will be my last resort. ill try testing the other parts first before i replace the keyboard controller. thanks for giving time for this suggestion.
                            • valiant007
                              Comp Technician
                              • Dec 2012
                              • 44
                              • philippines
                              #34
                              regards
                              thanks for the suggestion. actually im quite new on board level repair so any suggestion you give me on how to check and what to look for is a lot of help for me. ill try all your suggestions. thanks for giving time to give me this suggestions. it is greatly appreciated.
                              • valiant007
                                Comp Technician
                                • Dec 2012
                                • 44
                                • philippines
                                #35
                                i still have a prob with this. does any of you guys have other suggestions?
                                • heavymachines
                                  • Mar 2011
                                  • 1028
                                  check for shorts if both touchpad and keyboard not working see if there is a component on motherboard that shares resources between those two i/o's check for shorts, corrosion etc sounds like possible liquid damage check it over use a schematics to show you all what is what that controls those functions .
                                  • User555111
                                    A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                                    by User555111
                                    Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                                    02-05-2024, 08:16 AM
                                  • B2L_Repairs
                                    Macbook A1706 touchpad and keyboard not working. Please help
                                    by B2L_Repairs
                                    Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                    10-09-2023, 04:56 AM
                                  • fichamba
                                    MSI GL75 Leopard keyboard (almost) not working - HELP
                                    by fichamba
                                    Hello everybody:
                                    Let me put all the laptop's info before describing the problem:
                                    BRAND: MSI
                                    MODEL No.: MS-17E7
                                    SKU: GL75 Leopard 10SEK-261XES-BB71075H16GXXDXX
                                    MoBo: MS-17E71 VER. 1.0
                                    This laptop arrived to fix the broken left hinge, due to a hit. The hinge was repaired, and when I went to check it out, everything worked well, but I observed certain artifacts (mainly random lines) in the screen.So I decided to remove the screen bezel again, and I saw certain damage to the main LCD harness.
                                    This time I also observed that the right...
                                    10-09-2024, 04:53 PM
                                  • Vliegenier04
                                    Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
                                    by Vliegenier04
                                    Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
                                    I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
                                    Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
                                    06-16-2025, 12:03 PM
                                  • hopkok
                                    Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                                    by hopkok
                                    Hi masters, I need your help.
                                    I am working on Lenovo Legion 16ITHg6
                                    Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                                    INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                                    My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                                    AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                                    Power LED is not working as well, power button working well.
                                    UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                                    Motherboard...
                                    05-04-2025, 09:35 AM
