Macbook Pro 13" PBus issue
  • davis12
    • Nov 2012
    • 26
    • denmark
    Hi Guys!
    Im new at this forum and it really looks promising so far.
    I am an ACMT for the last couple of years and just now i started to study the world of component repairs.
    I have this Macbook Pro 13" A1278 (MacBookPro8,1) logicboard that runs very slow because of high CPU usage, in activity monitor i can see the Kernel_task on 380%+- all the time.
    I then tested the MLB with another known good Topcase and the issue persist, which points to faulty logicboard.
    I run Apple Diagnostic Test (ASD) and failed on Sensor-Voltage (VP0R)--PBus (Test 1)- Sensor is reading below the low limit.
    I then read about PBus and found that it belong to the battery controller and in the ASD test results guide i can see that the VP0R is the PBus rail which i don't know what is (yet).
    My question is which one is the VP0R? and is it possible to fix it?
    I have an SMD rework machine (Aoyue 968A) and ready to start actually using it..
    As i said before my knowledge about components is not big at all but I'm more then willing to gain some knowledge and this forum look like the right place to do so (:
  • davis12
    • Nov 2012
    • 26
    • denmark
    Re: Macbook Pro 13" PBus issue
    am i doing somthing wrong with this thread or there is not many that know about apple logicboards??
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      You say PBus belongs to the battery controller. Does the issue persist when you remove the battery?
      I do not, and have never owned a Macbook (too expensive, plus i hate Linux and OSX fonts with a passion), but i browse the Apple support forums sometimes, and i've noticed lots of people with kernel_task issues. The solutions were of the most diverse, in fact, i don't even know if i read of two machines that got fixed the exact same way.
      Edit: Forgot to add, what are the temperatures, and how fast does the fan run? It can also point to overheating.
      A working TV? How boring!
      • davis12
        • Nov 2012
        • 26
        • denmark
        Spot on! when i remove the battery and restart the machine no issues at all and the killer Kernel_task is gone..
        I also testet with a known good battery and the kernel_task is back to life but no high temp or high spinning fan, quit as the sea but very high CPU usage.
        Any ideas?
        I can upload pictures of my logicboard if needed.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          This sounds like a hardware issue but you may be able to work around it.
          As far as my understanding of OSX goes, kernel_task runs a bunch of kernel extensions under it, kinda like svchost.exe does on Windows machines. There are software tools available which break down kernel_task into its child processes, and show you what each of them does and the resources they use. You'll have to google it but i'm sure you'll find these tools easily. That way you can pinpoint the resource usage to a single process, and see what can be done about it.
          I understand the machine does run on battery, right? Just that it's slow with high CPU.
          • Abdul Rehman
            • Nov 2012
            • 5
            • Pakistan
            your machine required the factory default settings
            • davis12
              • Nov 2012
              • 26
              • denmark
              Yes it does run on battery but thats also what provoke the kernel_task/CPU usage.
              The strange thing about all this is that one thing is that i know it is a sensor VP0R as the Apple Service Diagnostic points to and i know that it related battery and fixed when the battery removed but i also found out that there is no issue with the kernel_task and the CPU usage when i boot into safe mode..
              So is it software or hardware issue? is it both? i obviously need to find out which kext is responsible the reporting of faulty sensor which cause the high CPU usage and delete it in.
              Also if i only knew where is this VP0R sensor located on the board and try to replace it but as i mentioned before i don't know that much on components level or reading those diagrams (:yet)
              • davis12
                • Nov 2012
                • 26
                • denmark
                a
                • davis12
                  • Nov 2012
                  • 26
                  • denmark
                  Do you mean clean install??
                  it does the same thing with extern system with 10.7, and the system is a fresh copy of mountain lion 10.8.
                  • mohan912
                    • india
                    Hi........I have a macbookpro A1278 model and at one moment when i as working plugged in with power, suddenly the fan started running at a high speed,more heat at the bottom and the machine got switched off .Before that my battery was in a good condition. After this instance when i plug in the power adapter to my MBP the green light is not glowing and not charging the battery.The battery indicator is not at all working.So.emphatically my MBP behaves like a brick.No response from power button also. Someone plese suggest me what would be the problem inside the Machine.
                    • fr3nch
                      • Oct 2015
                      Im having this same issue. Can you give us a little follow up on how your situation turned out?
                      • guruji
                        • Oct 2012
                        • 120
                        • India
                        hello,
                        i have a macbook1278 820-2936 same problem when u use the adapter is works perfect and when u run only in battery the cpu usage hig the trakpad gets jittery and becomes to slow the machine. i have changed the smc chip battery.
                        pls does anyone know where to look for the problem
                        thanks
                        • jakkal
                          • Jan 2015
                          • 8
                          • Portugal
                          Check area q5300 pbus voltage sense.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            So have you tried this https://support.apple.com/en-us/HT201295
                            • rounin
                              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                              by rounin
                              I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                              🛠 Original Issue
                              The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                              04-19-2025, 01:18 AM
                            • pcbmaniac
                              MacBook A1278 (3115) No PPBUS_G3H Issue
                              by pcbmaniac
                              Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                              I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                              1. U7000 Measurements:
                                • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                              2. Resistors:
                                • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                              Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                              • If I also decide to replace the SMC, do I need to order it pre-programmed,
                              12-02-2024, 04:12 PM
                            • sofles
                              Macbook a1707 2017 model 820-00928 GPU issue
                              by sofles
                              Hello there
                              I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                              I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                              11-21-2024, 05:25 AM
                            • Stephen
                              A2141 MacBook Pro 16" lid sensor issue.
                              by Stephen
                              Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
                              11-01-2024, 03:45 PM
                            • Gueric
                              MacBook Pro 2019 820-01700 Speaker amp issue.
                              by Gueric
                              I have this MacBook Pro on my bench that I have already fixed, hard short on a SSD rail, but it also has another issue. the right speaker sound is either earrape, muffled or absent. Left one works perfect. I have tried replacing it, nothing changed so I'm pretty sure the issue is either motherboard related or maybe software but I doubt that.
                              I don't how to troubleshoot speakers. Any help would be very much appreciated.
                              A refurbisher and a repair shop have already been inside the laptop but I'm pretty sure none of them tried to do any soldering on the board.
                              05-19-2025, 03:08 AM
