Nikos mosfet
    Nikos mosfet
    I have NEO netbook ,the problem is when i connect the ac charger i notice that the led of the charger is blinking so i open the machine and looking for the shorted parts and i found it.,a smd caps & a SOP-8 mosfet which is located near j-mbat1.,the model is NIKOS PD1503YVS,.i can't find a datasheet for this IC so please help me.is there any compatible replacement for this IC?
    Re: Nikos mosfet
    Does the mosfet not have any writing on it at all? The cap can be replaced with similar size. It's not perfect, but for the most part ceramic SMD caps are designated by their size. Take a junk laptop apart and you'll find one you need off of it.
      Re: Nikos mosfet
      Hi did you find this;http://products.niko-sem.com/index.p...od_list&cat=19
      Please can you update your profile with Country and Mains Voltage
        Re: Nikos mosfet
        thanks mattbrad2 .,but i already replaced the smd caps and the remaining problem is the mosfet .,it is shorted.,i can't find any replacement with the same spare parts .,
        thanks selldoor for the link..
          Re: Nikos mosfet
          Perhaps one of these would work? FDS6982AS
          Any laptop gurus watching?
            Re: Nikos mosfet
            ok i'll try it..,then i'll tell you what happen..thanks in advance..
              Re: Nikos mosfet
              Ao4932
